2004 v70 2.5t pulls right when accelerating
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
One bad bushing out of 4 is not enough to cause severe subframe movement. Most likely you didn't align the subframe when it was bolted on after bushing replacement. Easy to overlook.
This thread is going to stretch onto its second page soon, yet we didn't see wheel alignment numbers! No point in chatting about driveability problems without knowing the numbers. Can't help.
shoebox
Year and Model: 2004 XC90 2.5T FWD
Has thanked: 7 times
Post by shoebox »
vtl wrote: 30 Jun 2017, 09:17 One bad bushing out of 4 is not enough to cause severe subframe movement. Most likely you didn't align the subframe when it was bolted on after bushing replacement. Easy to overlook.
I have an 04 XC90 but please do you know if this tool is required to align the subframe? https://www.adverts.ie/other/genuine-vo ... 4/14716348
sillygurl1968
Year and Model: 1998 S70 GLT
Post by sillygurl1968 »
1998 volvo s70 turbo AT. Need some help figuring this out...ive replaced both cv axles, both strut/shocks/ both sway arms..control arms are 2 years old. And had a front end alignment tires are new air up properly... So it feels like all the weight is on the axles i can feel every little bump in the road and it hits like i hit a mountain. It sorta feels like a tire is woobling as well theres alot of brakepad dust i just cant figure what it could be
chrism
Year and Model: S80 / 2005
Been thanked: 89 times
Post by chrism »
“… control arms are 2 years old…”
Were those control arms Volvo brand or aftermarket?
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
oragex wrote: 29 Jun 2017, 11:58 At 120k you have the lower torque mount (the small one right at the bottom from of the engine) as well as the upper torque mount that go bad. Check both of them. The lower one I think it's harder to replace.
I would then look into tire pressure, then control arms as mentioned above. An alignment wouldn't hurt but not sure that would cause pulling only under acceleration.
Hit the forum to find which aftermarket parts are worth buying ;)
They are both easy to replace, but I advise replacing them in pairs. Basically if one has gone bad, the other one picks up the slack and both go bad.
EDIT:Wow I must have necroposted.
