Problem after replacing control arms
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
If it pulls to the right, go to the LH control arm and double check that the mounting bolts-to-chassis are tight. If the bolts are tight take a good look at the bushings. If it pulls left then check right.
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
Could you have hastened the death of a motor mount whilst working on the car?
Sorry to "just guess" again.
precopster
- Year and Model: Lots
- Been thanked: 128 times
Upper bolt holes on struts are elongated. Did you mark them and place them back to previous position? The camber adjustment is important.
I'd still get an alignment and let alignment place know of that camber adjustment point I mentioned.
You Tube has videos on a toe-in procedure.
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
No - that I missed. I will get it aligned once I make sure there is nothing wrong with the install. The sudden shift from driveable to "this thing is going 20 degrees left, from where I have it pointed" (and back), makes me think there is something I missed. After that scare, I drove the car home with gentle acceleration and didn't have a problem.......
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
azureblue
that's what I'm guessing. The old bushings were bad but not gone, and the car tracked straight ahead with no pulling to either side, before I replaced the control arms. I thought maybe the ball joint bolt did not seat right into the control arm, but that's not it either. It feels like something shifts when I put on the power, and causes the jerk to the left. The rain stopped me from looking at the right side today but the left still looks like it should. The only thing that is an if is torque value on the rear bushing - I gave it a good pull with a breaker bar to tighten it down.
I may try getting both front wheels off the ground and watching the wheels while someone turns the steering wheel..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
azureblue
The front bolts are horizontal and the rear mount bolt is vertical. The control arm has to be more or less horizontal to get it into place. Ever done one?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
precopster
You don't"t need to put weight/preload on the control arm on a P2. Different setup to P80.
- 1711 Views
Last post by jonesg
- 3330 Views
Last post by THAI UNG
- 1961 Views
Last post by chris11211
- 4334 Views
- 2448 Views
Last post by SVO LOU
