I recommend the following:
1. Valve stem seals
2. Would do the rear main seal is it is NOT bone dry.
3. Damaged hydraulic engine mounts.
4. Turbo coolant lines.
5. Turbo coolant lines if they are leaking.
The Volvo owner's manual states that you should NOT let these cars idle, they will smoke.
I only use the Volvo plugs.
850 Platinum Edition Wagon engine swap/ rebuild
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- 20 Replies
- 6693 Views
Last post by Clemens
- 2536 Views
Last post by misha
- 20 Replies
- 3653 Views
Last post by phils94850
- 13 Replies
- 2969 Views
Last post by wizechatmgr
- 11 Replies
- 3684 Views
Last post by Salomons Driveway
