S70 still wont hold idle...
Has thanked: 1610 times
Been thanked: 4068 times
If you don't get the 8 second whine , which is the self test, it isn't matched up right. Search Mike's posts (user precopster) for the Guru of Italian Throttle Bodies for more info on this.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Look at the numbers next to the barcodes, your part and version numbers don't match. See the advice about flashing/cloning you ETM
Current Volvos:
Larry_Dean
Year and Model: 1999 Volvo S70 AWD
Post by Larry_Dean »
I sprayed starting fluid in the intake air temp sensor hole and the car started. Now with the iat sensor back in it will bounce off of the idle. From 800rpm to around 1.5-2k rpm. And it will continue doing this.
