Severe oil leak on S70 glt
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Looks like your upper torque mount bushing is dead.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Your top engine mount is toasted.
85 GLH, 367 whp
00 Insight, 72 mpg
Has thanked: 1613 times
Been thanked: 4078 times
I've always wondered what that extra stud is on the manifold on my 99 and your pic with the EGR just enlightened me!!
Fix that upper engine mount stat before it ruins your radiator and engine mounts
RDR89
Year and Model: 1998 S70 GLT
Post by RDR89 »
Yes, I saw that right away. I am compiling a list for the end of the month to purchase. Looks like the previous owners enjoyed the turbo.
RDR89
Post by RDR89 »
rspi wrote: 16 Sep 2017, 07:07 It is my opinion that the cam cover (they do not have valve covers) on these do not leak. If it is leaking, it's been leaking since installed.
If the leak is on the drivers side, higher than the axle, it is likely a rear cam seal.
This is the issue exactly! The engine compartment was so gooked up with oil buildup I could not see anything. After the clean I could see the trail from the rear cam seal. So in all likelihood the PCV is blocked up.
Thanks! One thing leads to another right?
Has thanked: 2215 times
Been thanked: 1853 times
Hate to add to the list, but if the top mount is as bad as it is, check the condition of the lower torque mount, in particular the smaller rear bush as it has been working over time. Also check the crank pullet engine mount. Place a floor jack with a piece of wood between the oil pan and the jack and gently jack the RH end of the engine. Have the RH wheel off and the plastic inner fender liner pulled back at the front. When they go bad and you jack the engine gently you will see the rubber portion and the metal base plate will separate.
Good luck!
