Any bypass pulley? Ac seized...
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Eric. Google is your friend here. IPD stocks a serp belt for models w/o AC and provides a picture of the belt routing. All you really need is that picture. You can undoubtedly get the belt locally. My compressor pulley seized and I ran with a short belt for a while. The routing of the belt run is completely different. Your local dealer or NAPA, AutoZone, etc., will likely have an appropriate belt. No need to be adding any pulleys here, you are just bypassing the compressor.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
The computer needs a good 12 V supply, it doesn't matter if it comes from the battery or the alternator
An alternator will generate voltage turning either way ( and not -12 V either) but you probably have the free wheeling AC pulley on your car so it will only charge turning the right way.
I thought serpentine belts were grooved on both sides? Or am I confusing with timing belts?
- E Showell
Pretty sure smooth on one side, grooved on the other, but it shouldn't matter. Get the proper belt and route it correctly and you'll be fine.
'95 855 auto (sold)
'95 855 auto (sold)
Ive got a good visual on this from recent work
Crank pulley, power steering pump and AC ride on one side of the serp belt
Tensioner and Idler ride on the other side
Both sides ribbed - now I remember one side of mine is cracking (the tensioner idler side) and the other looks good. Im going to flip it and run it another 200k miles at my next used oil change.
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
Let me check on making sure it is something I did pull from my '98 and if it can't be used on this post, it is up for grabs.E Showell wrote: 01 Nov 2017, 17:53 Shane, I might be all over that compressor. I have a bad one in my '98.
Shane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
- 1460 Views
Last post by bmdubya1198
- 7118 Views
Last post by oragex
- 1422 Views
Last post by XC70Rider
- 86 Replies
- 23183 Views
Last post by herbakis
- 5428 Views
