S90 no start Topic is solved
TerrDawg
Year and Model: 97' V90/98' S90
Has thanked: 7 times
Been thanked: 13 times
Post by TerrDawg »
Good stuff, will do that today AND THANKS
07' XC 70 Black/Lowered 136k mi
98' S90 blue 245k mi
98' S90 white super clean ! 274k mi
TerrDawg
Post by TerrDawg »
I pulled the starter relay, probed and found one hot lead, then I tried the balance of the probes and there was nothing. I then swapped the relays and had the same result. I put a jumper wire from the small connector on the solenoid to the white empty lead that I've read is the PnP bypass. Nothing... And no test light when key is in start position at that. Bypass connection.
I then checked my V90 bypass connection and the IS power at that connection, so, maybe switch?!?
So back at the S90, I put two spade connectors at the small solenoid, ran that jumper up and hooked a momentary switch to power and started right up and purred oh yeah, except ... The ABS light is staying on !
I downloaded the wiring diagrams but will have to research it tomorrow
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
I downloaded the wiring diagrams but will have to research it tomorrow.
I went and probed my 97. Standing at the driver's side fender. The 6 o'clock socket position is terminal #1 (the one closest to the fender). From there the terminals number off counterclockwise.
#1 (6:00) Main power from main fuse box.
#2 (3:00) From ignition switch.
#3 (12:00) PnP/Starter
#4 (9:00) Coil ground.
#5 terminal to the cruise control does not physically exist, it just a tap off #3.
The center "terminal" has no electrical connection and therefore is electrically meaningless, it just serves as a key to make sure the relay cannot be inserted incorrectly.
Stick your test light in #2 (3:00) and hook the other end to a ground. Turn the key to start position, the test light should light. If it does not, ignition switch or anti-theft is the problem.
Place a jumper between #1 (6:00) and #3 (12:00), if the starter kicks in, the PnP switch is good and you can put the PnP switch out of mind.
Forget all the other stuff you read about PnP bypass . If you follow the instruction above we can narrow this down, with certainty, right at the relay socket.
Active
Past
RickHaleParker
TerrDawg wrote: 10 Nov 2017, 13:32 I understood the white connection under the fuse box was a starter bypass
Sounds like the jumper terminal for Manual transmissions. This is shown as BLU M/T only on the wiring diagram. It would work as a PnP bypass on cars equipped with an automatic transmission.
Active
Past
TerrDawg
Post by TerrDawg »
Agreed, it is hot on the wagon when in start position but on the sedan it's definitely not.. both are automatic transmissions
I grabbed center console relays while at pick n pull, the diagram shows it being the location of the security alarm system relay - I'll try that tonight
RickHaleParker
TerrDawg wrote: 13 Nov 2017, 14:40 I grabbed center console relays while at pick n pull, the diagram shows it being the location of the security alarm system relay - I'll try that tonight
The relay is marked "alarm system" ... did you grab the right one?
https://www.ebay.com/itm/1997-98-VOLVO- ... 2548.l4275
You can also probe for the ignition switch start signal at security relay socket.
Active
Past
TerrDawg
Post by TerrDawg »
I'll be damned .. I did not grab the right one, I seen three and didn't see that one, the three I grabbed were on the passenger side - where is that one?
RickHaleParker
Not 100% sure on the 97-98 but .... On the 95-96 960 the relay panel was in the center of the center console. To gain access to you remove the ash tray. I think the security relay is on the other side of the panel you pulled them other relays from.
You might try removing the trim to gain access.
To remove center trim:
1. remove ash tray
2. two screws on bottom of trim
3. Pop out the trim with a bone tool of some other plastic tool.
I use Jewelers screwdrivers but you got to be careful not to let them slip and scratch the trim.
Active
Past
TerrDawg
Post by TerrDawg »
Guess What, ... Aftermarket alarm system found..!!
Will uninstall this weekend, I'm sure this is my problem... Also key fob batteries seem to be dead, with all the battery swapping, disconnecting and finally new battery and alternator.... I'm sure it's in protect mode - will keep you posted
TerrDawg
Post by TerrDawg »
Uninstalled secondary alarm with magnetic PASS key ... EVERYTHING WORKS NORMAL
Thanks for all your help
Terry
