I read somewhere that they must have been quite keen keeping their suspension geometry to themselves, because according to the owner of a surviving 850 race wagon most racecars and prototypes were destroyed and his came with no suspension, if I recall correctly.
That NA motor was quite interesting. In fact they had problems with the intake ports of the head being too restrictive. Since they had to use the stock head though, they cut off parts of the head and mounted it in a different angle, thereby improving the flow.
Volvo's BTCC history - two wheels up
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
Standard MacPherson setup with coilovers, with remote adjustment. Look at the scuttle and you can see the oil reservoirs remotely mounted. Look at the black brackets just inwards of the original shock mounts and those are where they mount. They moved the mounts inboard to allow for added camber and clearance options.BlackBart wrote: 18 Feb 2020, 21:40 Really interesting how far they moved the motor back - it's even with the strut towers. And they must have changed the front suspension geometry, as the top of the strut is removed. Maybe a lower lighter coilover type.
- Has thanked: 2854 times
- Been thanked: 1332 times
So, so far back. Way back.BlackBart wrote: 18 Feb 2020, 21:40 Really interesting how far they moved the motor back - it's even with the strut towers.
Interesting, thanks.Cookeh wrote: 19 Feb 2020, 07:10Standard MacPherson setup with coilovers, with remote adjustment. Look at the scuttle and you can see the oil reservoirs remotely mounted. Look at the black brackets just inwards of the original shock mounts and those are where they mount. They moved the mounts inboard to allow for added camber and clearance options.
I bet that motor sounded awesome.Clemens wrote: 18 Feb 2020, 23:46 That NA motor was quite interesting. In fact they had problems with the intake ports of the head being too restrictive. Since they had to use the stock head though, they cut off parts of the head and mounted it in a different angle, thereby improving the flow.
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
I was just thinking the same thing. Open exhaust with no turbo in the way on a high revving straight five!
Tried to look up up some noises....
And some on-track action....
My God. It sounds glorious.
- Been thanked: 4064 times
...what a beautiful waterfall grill.....
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
So I have two favorite Number 14 cars now.
- 60 Replies
- 11231 Views
Last post by bmdubya1198
- 4428 Views
- 7819 Views
Last post by jimmy57
- 13 Replies
- 9784 Views
- 14 Replies
- 4887 Views
