2001 V70 2.4T Oil pooling in the wells around ignition coils, Permatex 51813 cam sealer Topic is solved
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
To me it doesn't look like it's coming from the filler cap. Should be stickier in that area.
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Post by prwood »
Rattnalle wrote: 09 Nov 2017, 13:52 To me it doesn't look like it's coming from the filler cap. Should be stickier in that area.
Yeah, it's always been pretty clean around the oil filler cap, which is why I'm always skeptical as to that being the source.
Based on where it's pooling, I'm actually wondering if it's leaking from under the screws on the valve clearance inspection holes, or from under the screws holding on the cam cover? I've done some Googling and thus far I haven't seen anyone else identify that as a possible culprit. But it would be simple enough to remove those screws, clean and inspect the screws and the holes, and replace/retorque them. I have the torque spec as 20 Nm.
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T; 2004 Honda Odyssey
- 2007 to 2015: 2002 Subaru Legacy L Wagon
- 2003 to 2016: 2001 Toyota Corolla LE
- 1999 to 2003: 1994 Toyota Camry LE
prwood
Post by prwood »
Found the source of the leak. There is oil seeping from under the boot of ignition coil #4. Due to the incline of the engine it runs backwards into the wells around the valve clearance inspection holes.
So... Now what?
Cars I've owned:
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
5 o rings between the two halves of the cylinder head are probably cracked or were improperly seated during installation if the head has been off. Dorman sell a nice inexpensive kit for this or just go for Genuine.
prwood
Post by prwood »
precopster wrote: 10 Nov 2017, 00:26 5 o rings between the two halves of the cylinder head are probably cracked or were improperly seated during installation if the head has been off. Dorman sell a nice inexpensive kit for this or just go for Genuine.
Any pointers to a tutorial on how to remove/replace the top half of the cylinder head? The procedures I'm finding online are for removing the entire cylinder head, which I'm hoping isn't necessary.
Cars I've owned:
precopster
Remove strut brace. Remove plastic covers and turbo pipe. Peel back all the wiring and remove coil packs. Remove timing belt. Remove engine torque rod.
Remove rear mounted cam sensors.
Remove 42 x M7 bolts then crack apart the 2 halves with a soft mallet or a specialised tool which separates the head at the separation points.
You'll need anaerobic sealer to re-assemble. Torque on the 42 bolts is 17Nm.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
1. Clean it off 2. Add some UV dye to the oil 3. In the dark, High idle it under a UV lamp ... watch to see where the oil is coming from.
Active
Past
prwood
Post by prwood »
precopster wrote: 10 Nov 2017, 07:17 Remove strut brace. Remove plastic covers and turbo pipe. Peel back all the wiring and remove coil packs. Remove timing belt. Remove engine torque rod.
Do I need to use the Volvo branded sealer, or will any off-the-shelf anaerobic sealer do? This is one I can get locally:
https://shop.advanceautoparts.com/p/per ... =anaerobic
Cars I've owned:
Has thanked: 1610 times
Been thanked: 4071 times
I haven't done one of these but Permatex is a pretty solid brand for sealants.
Let the experts chime in, though. Did you try a re-torque just for laughs?
prwood
Post by prwood »
abscate wrote: 10 Nov 2017, 16:15 I haven't done one of these but Permatex is a pretty solid brand for sealants.
No, I stopped once I saw there was no oil coming from under the bolts.
Cars I've owned:
