Update
The return hose , part number 30713304 shoes as NLA ON FCP
1999 V70T5M Oil Cooler and seals 30637339 (Biscuit style on rear/RHS of engine
- Been thanked: 4064 times
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
You sure?
I will do some sole checking, unless your post is just laced with sarcasm.
Don’t you have a server to go check somewhere in Utica?
- wizechatmgr
Moved the contents of it back to "home."abscate wrote: 02 Mar 2019, 03:10 I will do some sole checking, unless your post is just laced with sarcasm.
Quick update on this thread
If you are servicing an XC biscuit oil cooler you may need to remove the angle gear damper, a cigar box sized thing box below the gear. Have fun with that one, thread here
viewtopic.php?f=1&t=88994
Does this look right?
Red unfiltered oil
Green filtered oil
Blue filtered and cooled oil
Red unfiltered oil
Green filtered oil
- 1574 Views
Last post by SuperHerman
- 13 Replies
- 4695 Views
- 2062 Views
Last post by fitz548
- 3320 Views
Last post by darrylrobert
- 36 Replies
- 20879 Views
Last post by Achilles
