Well, I still did not get around to flush the transmission. However, a new problem just popped up: The orange arrow started flashing and the check engine check light came on. The code read: P0734 [Gear 4 incorrect ratio]. I have since eliminated the flashing arrow by excercising the shifter ~20 times. My question is: Is this new error code somehow connected to my original problem; that is, the auto transmission not being able to switch back to 1st gear resulting in a stall when coming to a stop.
Any inputs?
Thanks,
-Kef
1997 850 Transmission Downshift Problem
phoenix_iii
- Year and Model:
I'm looking at an 850T with this problem
No up arrow or cel.
It seems to stick in gear, and has problems downshifting... like a manual that is going to stall. Has 123k on it, no history.
What should I be looking at? Should I buy the car? Price is right...
No up arrow or cel.
- Has thanked: 17 times
- Been thanked: 35 times
Last 2 posts: Classic PnP switch (Park-neutral-Position). Look in the repair database....there are some write-ups (I believe) on how to replace the switch. Another (not long term) option is to turn the car on, put your foot on the brake and racket the gear shift from P down to the lowest gear and back up, quickly about 20 times....sometimes this will clean the switch enough to work again for a while.
phoenix_iii
- Year and Model:
Would that apply to my problem? The non-downshifting? Thank you!MadeInJapan wrote:Last 2 posts: Classic PnP switch (Park-neutral-Position). Look in the repair database....there are some write-ups (I believe) on how to replace the switch. Another (not long term) option is to turn the car on, put your foot on the brake and racket the gear shift from P down to the lowest gear and back up, quickly about 20 times....sometimes this will clean the switch enough to work again for a while.
JRL
- Year and Model: Several
- Been thanked: 16 times
Yes, that controls the shiftingphoenix_iii wrote:Would that apply to my problem? The non-downshifting? Thank you!MadeInJapan wrote:Last 2 posts: Classic PnP switch (Park-neutral-Position). Look in the repair database....there are some write-ups (I believe) on how to replace the switch. Another (not long term) option is to turn the car on, put your foot on the brake and racket the gear shift from P down to the lowest gear and back up, quickly about 20 times....sometimes this will clean the switch enough to work again for a while.
phoenix_iii
- Year and Model:
Hmm... So going from P to L 15-20 times should temporarily relieve the situation? If not, what else could it be? Could the ratcheting P to L NOT help and it still be the PNP (I would think it's possible). What else can I test/check before I commit to this car?JRL wrote:Yes, that controls the shiftingphoenix_iii wrote:Would that apply to my problem? The non-downshifting? Thank you!MadeInJapan wrote:Last 2 posts: Classic PnP switch (Park-neutral-Position). Look in the repair database....there are some write-ups (I believe) on how to replace the switch. Another (not long term) option is to turn the car on, put your foot on the brake and racket the gear shift from P down to the lowest gear and back up, quickly about 20 times....sometimes this will clean the switch enough to work again for a while.
Thank you!!
Of course, you should get your codes read. Autozone or other auto parts stores should do that for you for free, but if the ratchetting doesn't do it, then PNP replacement is in order.
phoenix_iii
- Year and Model:
MIJ, thank you for being so direct. I do not have any codes (that I can see). I am going to go buy the car and hope for the best.MadeInJapan wrote:Of course, you should get your codes read. Autozone or other auto parts stores should do that for you for free, but if the ratchetting doesn't do it, then PNP replacement is in order.
Last question. Do my symptoms sound like a no brainer PNP problem? Here is my original post on another forum (most of it)
"Looking to get into my first Volvo 850T. I drove it tonight. Fun!
*edit* No flashing arrow or cel light
The car I am buying from a dealer who got it at auction, but has a tranny problem. What is known.
1) 122k on the clock
2) Tbelt at 118k
3) Clean overall Price is right because of tranny.
He brought it to a friend mechanic who said it could be the TPS or other sensors...
Here's the deal.
Starts accelerating fine. Kind of jumps into 2nd gear, not exactly smooth, but not slamming either. Is okay when accelerating or getting on it.
It has a lot of trouble coming down from gear. Seems like it stays stuck in 3rd or 4th, and sounds like it's lugging the engine (staying in too high a gear, like a manual car in a high gear).
What he has been doing is when coming to stop, taking it from Drive to Neutral, it drops down, and then putting it back and drive and going.. Has put 2k on it doing this. "
Appreciate your time on this. I will be making investments and repairs based on the advice I find here.
I forgot what all was posted before this, but I would do a drain and flush with the tranny fluid and see if the shifting improves. You do not want to keep putting it in to N as the car shifts.
phoenix_iii
- Year and Model:
Why not (shifting into N)?MadeInJapan wrote:I forgot what all was posted before this, but I would do a drain and flush with the tranny fluid and see if the shifting improves. You do not want to keep putting it in to N as the car shifts.
Also, is it possible for there to be codes without a CEL or other light indicator.
- 401 Views
Last post by gswede
- 872 Views
Last post by polskamafia mjl
- 562 Views
Last post by Clemens
- 644 Views
Last post by samjaynz
- 640 Views
Last post by chexny
