I also did not know about this "plate/cover" under the crankscase pulley until he showed me the gasket used with this "plate/cover". I then looked at Volvo part catalog and saw a small rectangular shape "plate/cover" right under the crankcase pulley. I don't know what to call this and the purpose of it. Volvo mechanic kept thinking that was the source of oil leak. He said that this happened before to other customers.
My car is NA so no oil cooler pipe into radiator in passenger side. It only has transmission cooler pipe into radiator in driver side.
Thanks,
Ching-Ho
1995 855 NA: Oil leak next to oil filter area
- Has thanked: 2197 times
- Been thanked: 1851 times
The plate is the blanking plate for the oil cooler thermostat. Perhaps the cover has been over tightened and is warped? I recall seeing this on an 850 NA we used to have now you mention it.
Maybe worth replacing the oil seal gasket on the cover plate again, but make sure there are no nicks or damage to the block surface and the cover plate is flat and not bent or twisted if the mechanic is sure that is where it is leaking from.
- RickHaleParker
- Been thanked: 977 times
"He kept thinking that was the source of leak or oil filter leak....."
Insanity is repeating the same mistakes and expecting different results -- attributed to Albert Einstein, origin undetermined.
Active
Past
Past
- 14 Replies
- 3085 Views
Last post by eriscentro
- 12684 Views
Last post by JudgeRat
- 1675 Views
Last post by Sydt
- 1551 Views
Last post by veektor
- 604 Views
