Good first result. As you have found, this forum and other related material can get you through this! Search the PCV threads here and you'll see how it works, how it goes bad, and how to fix it.
Do you and Mum have service records for the car. A GREAT resource.
Volvo newbie care help
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Current Volvos:
- RickHaleParker
- Been thanked: 979 times
I have to admit not knowing what the idle air control or PCV is or their purpose.
The idle air control is a second throttle body. Its purpose is the same as the main throttle body, regulate the engine speed but it only kick in when the engine is at idle. The smaller size of the idle air control allows for finer control then the main throttle body.
Positive Crankcase Ventilation, a one way passage for gases to escape in a controlled manner from the crankcase. Purpose keep gas pressure from building up in the crankcase.
Active
Past
Past
wlkstout
- Year and Model: 1998 V70 na
- Has thanked: 3 times
I had an Oldsmobile once that the Throttle Positioning Sensor went bad on and would give me erratic idling as well. I am not sure of the IAC on Volvo's exact makeup, just bought my Volvo last week, but on the Olds when you removed the IAC they had an o-ring around them. Onetime the o-ring had disintegrated and caused a slight vacuum leak on it. Also maybe a cleaning of the IAC and throttle body might help. Just take them apart and clean with brake fluid or throttle body cleaner. Welcome from another newbie. Good luck.
1998 V70 SW 2.4l na
1992 Olds Cutlass Supreme 3.1l
1994 Dodge Dakota 3.9l
1993 GMC 1500 5.7l
1993 GMC 1500 5.7l
