Just did, no dead shorts.
1998 S70 PnP switch 9466012, bad aftermarket new part Topic is solved
ferocity02
- Been thanked: 14 times
- RickHaleParker
- Been thanked: 977 times
It comes and goes, did you move the cable around and stress it, in attempt to recreate the conditions?
Active
Past
Past
ferocity02
I have wiggled the cable around as much as possible and no dice. I'm going to try shaking the TCM and it's connections. I did unplug the mode switch completely and it gave me a signal high code, AT-125 I think.RickHaleParker wrote: 12 Feb 2018, 22:17 Just did, no dead shorts.
I'm contemplating swapping the TCM, they are pretty cheap used.
- RickHaleParker
Try that again but this time manually hardware a mode.
Economy mode = Green-Orange grounded + Brown-Green open.
Sports mode = Green-Orange Open + Brown-Green grounded.
Weather mode = Green-Orange grounded + Brown-Green grounded.
Use a known good ground point. Don't use the ground to the mode switch.
Active
Past
Past
ferocity02
Yep. I did this too and it checked out.RickHaleParker wrote: 13 Feb 2018, 14:39
I'm curious if there is an issue with the wiring, because if I hold down the "W" for 25+ seconds, it does not throw a fault. This would indicate that the TCM is not receiving the signal from either wires.
I appreciate your help with this!
ferocity02
I pulled apart the green connector at the drive mode switch and cleaned and tightened up the contacts. Then I ran another ground for this switch to the same ground point as the parking brake switch. Not sure if this will help at all.
Regarding the holding "W" down for 25 seconds causing a DTC. I found out that holding it down will rather throw code AT-121 Shift solenoid S1, short-circuit to ground. This does not cause the transmission up arrow to flash or the check engine light to appear.
Not sure what to make of this code?
ferocity02
I replaced the TCM and no dice...
Any other suggestions?
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Know anyone in a neighboring state that doesn't follow CARB? Get it registered there.
How intermittent is the issue? Intermittent enough to get it to pass every x attempts?
ferocity02
It's become more consistent now... The transmission will fault (flashing up arrow, stuck in 3rd) every third or fourth drive. This is not long enough to get the car's self-checks to pass. And the smog tech generally has to start/stop the engine several times during the test.wizechatmgr wrote: 28 Feb 2018, 05:57 Know anyone in a neighboring state that doesn't follow CARB? Get it registered there.
- RickHaleParker
The only thing you have not replaced is the wiring .....
Active
Past
Past
- 11 Replies
- 11362 Views
- 14 Replies
- 2043 Views
Last post by bmdubya1198
- 1589 Views
Last post by davidvinograd
- 12 Replies
- 5117 Views
Last post by mrbrian200
- 1611 Views
Last post by beigg
