"New" Distributor Cap - Return or Install?
Has thanked: 1611 times
Been thanked: 4075 times
gmh wrote: 06 Feb 2018, 22:07
rspi wrote: 06 Feb 2018, 20:34 Was it made in a country that starts with a C and ends with an a?
Canada?
Colombia?
Croatia?
Cuba?
Czechia?
Cambodia?
I think that's it.
+ 100 points for claiming obscure country names
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Been experiencing random misfires/stalling, car restarts each time.
An afternoon of maintenance on the electrical connectors might pay immediate dividends.
Active
Past
jtp
Year and Model: 99 v70R
Has thanked: 11 times
Been thanked: 10 times
Post by jtp »
jjs70pdx wrote: 06 Feb 2018, 23:55 Thought I'd do some preventative maintenance/process of elimination. I'm not one to usually "throw parts" at a car, but I have minimal records from prior owner so not sure when parts were replaced. I've owned the car 4 years, put about 23k miles on it so far, and mileage is at 213k so I figured it may be due for the basic tune up items.
Been experiencing random misfires/stalling, car restarts each time. No codes. I've replaced spark plugs, but not rotor, cap or spark plug wires. Believe the spark plug wires are the originals as car is a '94 and wires marked "'93-43."
With that mileage and spotty maintenance history it’s a great idea to replace the cap, rotor, and wires on top of the plugs you already did. I’d do it whether or not the car was missing.
If it’s missing when cold and at lower RPM I’d move to a Seafoam treatment on the intake sucked through a vacuum hose after the cap and wires are done. If it’s missing hot at higher RPM/WOT then you’ll probably get it taken care of with the cap and wires
99 V70R AWD
Almost 155K Miles
Breaking is how I know it’s working
98 S70NA (sold)
95 850 Turbo Wagon (RIP)
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
OK yeah, then I'd definitely replace cap, rotor and wires. Good call! Especially those wires. Very likely to address the problem, perhaps even completely.
WhatAmIDoing
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
My "new" Bosch cap looked like that when I bought it (maybe marginally better). Supplier said it was cosmetic and didn't matter. Indeed it doesn't matter, as it fixed my misfire when cold and humid. That one should work just find if all the contacts look good.
RickHaleParker
Technically it does not matter but your suppose to get a discount for accepting something picky people won't accept, that does matter. I would not buy from him again, he is pocketing your discount.
Active
Past
wlkstout
Year and Model: 1998 V70 na
Has thanked: 3 times
Post by wlkstout »
I had misfires when i got my v70. Spark plugs fixed a lot but not all. The new rotor and cap fixed almost all except a slight one at idle while in gear. The newer (used) coil fixed the rest. Try those. And the distributor, could it be wear from being upside down in the box?
1998 V70 SW 2.4l na
1992 Olds Cutlass Supreme 3.1l
1994 Dodge Dakota 3.9l
1993 GMC 1500 5.7l
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
Not sure anyone has clearly answered your question "Return or Install?"
Install. Unless it bothers you so much that you're likely to have nightmares about pulling that spark plug wire off to find interdimensional lifeforms ooozing through those little pores in an attempt to exterminate all of humanity through your Volvo. In that case... install it. You'll need the car to make your doctor appointments.
mrbrian200 wrote: 08 Feb 2018, 00:23 Not sure anyone has clearly answered your question "Return or Install?"
Classic!!
mrbrian200
Snarky humor... Somewhat in line with the good old days before datalounge put up a paywall. They were a magnet for snarky brutal humor types. Sometimes with hundreds of hilarious replies to topics like "J.Lo wasn't nominated for any awards at the Oscars, her cameltoe looked angry. See link". Closest thing now, Reddit, flags/boots anyone who posts anything that might be interpreted as 'mean' toward anyone or anything. Basically, if it's actually funny you risk getting banned. Bill Maher has been complaining about this.. millennials having trouble differentiating between a joke/sense of humor and genuinely malicious intent.
