I will check the battery situation as it seems very logical. For now I have checked the LSM module and it indeed was in fault with the headlights. I never used the switch itself much, as in Finland we tend to keep the headlights on all the time. I opened the LSM module and pressed the little buttons there in order to clean the contact points and it indeed worked - the headlights now turn off when the motor is off and work normally. You know Volvos are good cars when parts get better the more you use it
Edit. some additional information
