Eeeek i stay clear of VS, i'm just going to assume V70 lpt 2.4L parts will work on the V70Rs hpt 2.4L. However I do know a guy in my hometown that has a inde volvo shop and builds R engins, only problem is hes been away for quite awhile.erikv11 wrote: 23 Jun 2018, 09:11 About the engine internals: Volvospeed is eerily quiet these days but the long-time posters over there will know exact and correct answers about this stuff, if you can pry it out of them and put up with the guff. You don't want book knowledge here (someone looking up engine numbers on the internet), you want to communicate with people who have done and seen dozens of swaps and rebuilds.
Volvo 855T engine swap using a 2.4T V70R Engine
- henrysin44
- Year and Model: 1994 Volvo 855 Turbo
- Has thanked: 2 times
- Been thanked: 3 times
Daily driver Black 1994 Volvo 855 2.3L Turbo - manual swapped, turbo swapped, green injectors, custom M4.4 Tune, de-catted, custom two-tone interior, V70R seats & rims
Teal 1994 Volvo 855 2.5L N/A Manual Transmission (the back up daily and parts car) - Runs and Drives but the engine knocks
Silver 1997 Honda CRV 2.0 AWD - its in a very sorry condition, but drives
Silver 2003 Subaru Forester 2.5L N/A AWD - Leaks everything
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
There is a EURO 95 R ECU ROM that can be used for both auto and manuals and without CEL come on. Only down size is the OBDII port doesn't work. Oh, no holding RPM during shift either.Ozark Lee wrote: 17 Apr 2018, 22:45 In a perfect world you would scare up a manual transmission turbo ECU. Without it you will have a constant CEL since the automatic ECU will not be able to communicate with the TCU (it gets removed). I think that Lucky has the manual software and he can re-flash your ECU to be a manual transmission version. The shifting is a lot easier with the manual ECU since it alters the throttle response (engine wind down slope) when you let off the accelerator. If you give him all of the specs of the build he can do a very nice tune.
viewtopic.php?t=76990
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- henrysin44
Really? I'm interested, does it work on M4.3? hmm does it still shift smooth with no REV hold or is it back to feeling like a 70s truck transmission. Lol I removed the check engine light and I've only used the OBD I port, gives way more info, plus my car is excempt from emissions in my state.tryingbe wrote: 24 Jun 2018, 17:50There is a EURO 95 R ECU ROM that can be used for both auto and manuals and without CEL come on. Only down size is the OBDII port doesn't work. Oh, no holding RPM during shift either.Ozark Lee wrote: 17 Apr 2018, 22:45 In a perfect world you would scare up a manual transmission turbo ECU. Without it you will have a constant CEL since the automatic ECU will not be able to communicate with the TCU (it gets removed). I think that Lucky has the manual software and he can re-flash your ECU to be a manual transmission version. The shifting is a lot easier with the manual ECU since it alters the throttle response (engine wind down slope) when you let off the accelerator. If you give him all of the specs of the build he can do a very nice tune.
- henrysin44
Sweet! I'm going to give it a try later, the BIN ive been using is giving me trouble
- henrysin44
Any chance you'd know if the file will work with green injectors and a 15T turbo?
tryingbe
If you can tune, yes.henrysin44 wrote: 27 Jun 2018, 13:04Any chance you'd know if the file will work with green injectors and a 15T turbo?
http://m43.wikia.com/wiki/M43_Wiki
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- henrysin44
Guess I can, sense I posted that I learned quite abit on VolvoSpeed. Had a M44 ECU laying around and with the right values the car runs amazingly now! I can shift so much faster now without the revs holding when i put the clutch in. I still have quite a lot to learn to even think about touching boost maps loltryingbe wrote: 01 Jul 2018, 08:56If you can tune, yes.henrysin44 wrote: 27 Jun 2018, 13:04Any chance you'd know if the file will work with green injectors and a 15T turbo?
- 2258 Views
Last post by henrysin44
- 761 Views
Last post by erikv11
- 1266 Views
Last post by thrashercharged
- 1359 Views
Last post by chitownV
- 15 Replies
- 9014 Views
Last post by precopster
