locked out Topic is solved
ashleybirch
- Year and Model: 2011 XC90
I will also hire locksmith near me] if see such lock trouble or getting myself in locksout situation.
- RickHaleParker
- Been thanked: 978 times
Raise the front of the car. Connect a float charger to the positive battery cable on the starter and a ground. This should trickle charge the battery, it might take a couple of days. When the battery is charged enough you should be able to use the remote to unlock the door.
Active
Past
Past
Im afraid MVS was too late on this one...
- Screen Shot 2019-02-27 at 2.52.35 PM.png (384.33 KiB) Viewed 1534 times
- tyguyc
- Year and Model: 2004 xc70
- Has thanked: 1 time
I used a piece of string about 5ft long with a slip knot tied loosely and I shimmied it down the door frame till I could loop it around the pull tab unlock thing (wow im bad at naming things). Then pull tight and pull up. took about an hour to get it all right, but I didn't have to call anyone.
TysonWheeler
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
These methods were mentioned in the previous posts.
