How to bleed air from power steering system
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Check your hoses on the reservoir to make sure they are tight. You should not be getting foaming - that indicates air in the system.
Bleeding any air should not take but one cycle run.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
June wrote: 30 May 2018, 08:06 Cycle the wheel all the way both ways before starting the car in the morning before the fluid becomes foamy. Check the level before starting as well. That was the process for Ford's many years ago and it worked. June
Don't do that with power steering!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
SuperHerman wrote: 30 May 2018, 13:10 Check your hoses on the reservoir to make sure they are tight. You should not be getting foaming - that indicates air in the system.
Air in the system is completely normal after flushing.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Danonly55
Year and Model: 1996 850 sedan
Has thanked: 23 times
Been thanked: 4 times
Post by Danonly55 »
Ok I started the car this morning and just rested the cap of the sump on top. I cycled the wheel back and forth slowly in full direction. I tightened cap and drove her for about 20 minutes and noticed as it got hot the slight jerkyness was still present.
I will top off sump and repeat tomorrow. I will update my results.
2014 Ford 3.5L ecoboost XLT
1995 Volvo 850 wagon GLE
Life is tough, but it's tougher when your stupid'
" John Wayne
misha
Post by misha »
It will disappear ...unless wrong fluid didn't messed something up...but i doubt it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
SuperHerman
As I understand the OP's situation is s/he has already changed the fluid and tried cycling a few times. S/he is still having problems. Usually foaming at this stage is air entering into the system from one of the reservoir bottle hoses.
Other possibility based on OP's last post "jerkyness" present could be a bad rack or PS pump. First OP has to eliminate fluid levels and hoses.
OP - prior to doing any work - how did the system function?
Danonly55
Post by Danonly55 »
The system functioned well with no jerkyness" I will check the fittings on the reservoir in the morning. If air is entering the system then I should see fluid leaking from the only hose I removed, that was the return line.
" John Wayne
