98 V70 driver's door electric window issue
C1ph3r
Year and Model: 1999 V70T5
Has thanked: 32 times
Been thanked: 7 times
Post by C1ph3r »
Neil, I know this is a very old thread, but any update on this? I have an issue with my drivers window that sounds similar. Mine just stops working up or down. That is until I turn the car off and back on again. After that it works just fine. This happens of course at the most inconvenient time. I have replaced 3 windows switches with new after market. Thank goodness for lifetime warranties. But I am certain since it has done it with both aftermarket switches it isn’t the switch. I do not know however if it did this with the OE switch. I hadn’t heard the car long enough to find out before I replaced it because the rear switches physically broke and needed replacing.
1999 Volvo V70 T5
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
Has thanked: 2197 times
Been thanked: 1850 times
The issue in this case was a lack of lube on the sliders and an aftermarket switch going bad. I swapped in another used master switch and lubed the sliders and the guides with silicon oil. So far that has been good. The other issue I have had with random issues with items working from the master switches is broken wires in the harness between the front of the door and the A pillar.
The wires over many years of door opening eventually harden and then the casing splits. I have repaired 3 or 4 harnesses for different issues including the passenger side door mirror. Actually in that case it was a broken wire in the passenger front door.
