Finally doing PCV - needed it big time
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Did you run a large zip tie down into the oil pan?
- SonicAdventure
- Year and Model: 1996 850 wagon
- Has thanked: 59 times
- Been thanked: 12 times
No I didn’t do that, handnt heard of it. I did blow into the lower port with a heater hose and the oil was heard gurgling with not that much of a puff.
One other thing I noticed after start up when I was doing the glove test was a vacuum type of a sound near the timing belt area. I know it’s wasn’t air sucking past the intake manifold because I double and triple checked torque on all intake bolts and used a new gasket.
Is it possible I am hearing the air rushing through the new breather box and fresh system the way it couldn’t have done with it as old and plugged up as it was, or is my imagination getting the better of me?
I really do hear a mini vacuum like sound from that area of the motor I’m not kidding!
- amblerman
- Year and Model: 1999 s70
- Has thanked: 2 times
- Been thanked: 70 times
On the timing belt side of the intake manifold there is a vacuum line nipple.
you can see it here in step 9.
viewtopic.php?t=28487
Is that hose connected? I can see that making a sucking noise if not connected. I'd be surprised if it air flowing through the breather box.
Note: my 1999 base N/A has that nipple. I'm assuming your 98 does but I know there are differences between the two years.
-A
-A
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Wow...they are dirty indeed. Use caution with carb cleaner if it's not rated safe for catalytic cnvtr & oxygen sensors. Best to use FI cleaner.SonicAdventure wrote: 23 Jun 2018, 16:27 Hey guys have car apart and trying to wrap up this job. Can I spray a little gumout carb cleaner in the intake valves, they look a little gummed up,
I'd recommend a couple of tanks of Redline Si-1 + gas, back-to-back, as a start.
M1 10W-30 HM
M1 10W-30 HM
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
That would be a good vacuum leak. It is a common one because the hose bend gets brittle.amblerman wrote: 25 Jun 2018, 12:53 On the timing belt side of the intake manifold there is a vacuum line nipple.
-A
Current Volvos:
- SonicAdventure
No it’s not that nipple on the passenger side of the manifold I checked and the hose is connected there. I think I might be hearing things. However I am pulling two new codes P0133 and P0422 a day after doing this whole repair so I’m not quite sure where to start with that. The car is running fine, other than the codes.
- 6069 Views
Last post by jimmy57
- 25 Replies
- 7141 Views
Last post by Blacklab467
- 1591 Views
- 795 Views
Last post by dmack87
- 38 Replies
- 7088 Views
Last post by Antoine240bk
