If I read this correctly, it is in backwards...AND ! the seal is flared evenly outward that little bit all around the crank.....should that lip on the crank face be flared in
Am I the only one ?
- Been thanked: 4067 times
Lineman1954
- Year and Model: 1995 850 GLT
then I feel a whole lot better knowing what may be the issue.
Lineman1954
Abscate, your suggesting that the seal should be flared in ?
Lets get a picture up rather than use 10E3 words...
[youtube][/youtube]
[youtube][/youtube]
Lineman1954
Thank You ! I've got the rubber mallet, need to source the "other tool" and a seal.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
I never put anything on the OD of a rubber body seal. That is somewhat like spraying oil on the soles of your non-slip shoes.
The only thing that ever needs to be applied to the lip of the seal is the exact lubricant it seals in. If the shaft the seal rides on is oily then nothing goes on seal.
Lineman1954
thanks Jimmy, short of buying a five hundred dollar specialty tool, what do you use to drive your seal in with to keep it perpendicular to the shaft ?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
That video is NOT the proper RMS installation tool. Anything short of the proper tool is risk. The OEM Volvo tool is 2 piece.
Lineman1954
so , do most guys use the proper tool ?
- Has thanked: 316 times
- Been thanked: 531 times
The tool doesn't seem to be necessary after reading around, but from previous experience with various other seals (I have yet to do the RMS, but I will be doing it before my M56 goes into my R) if you oil the edges of the seal (use engine oil in this case) and carefully press it in by hand and a soft face rubber mallet, socket extension, etc. to drive it home, while making sure the edges don't fold.
I'm sure it's one of those seals that is a pain to press in. That's how the crank seal was on my 740.
