Use genuine parts only for the engine coolant temp sensor, do not use after market parts for it. It is called as Temperature sending unit. It is recommended that you change the ECT sensor and Thermostat together. They typically last between 60-80K miles before they start malfunctioning. Here are links from FCP
https://www.fcpeuro.com/products/volvo- ... -9125463oe
https://www.fcpeuro.com/products/volvo- ... s-271664oe
98 s70 overheating
- RickHaleParker
- Been thanked: 980 times
I think Wahler is commonly used without problems, about $12
Wahler is a BorgWarner aftermarket line. BorgWarner claims Wahler is built to the same quality, service life and operational reliability as OEM.
Active
Past
Past
dj_v70
- Year and Model: v70 2003
- Has thanked: 7 times
- Been thanked: 23 times
I don't believe any of these codes have anything to do with your overheating issue. Googling P0176 says it is for a fuel issue. Someone else will chime in if I am incorrect here.
Based on the information that you have provided so far, it doesn't sound like your issue is the thermostat.
You have noted that it takes something like 10 miles to get up to temperature. That is likely the thermostat stuck partially open. This is a common issue with these cars. A thermostat stuck open keeps your engine cooler, not hotter though, so it is unlikely to be your overheating issue. I bought my 2000 v70 with a thermostat that was stuck open, it took about 10 miles to get up to temperature also, it didn't overheat.
It isn't hard to replace thermostat, I recommend using youtube to get in-depth instructions.
- Been thanked: 4071 times
Wahler, Vernet or OEM Volvo on those parts.
You will need a Torx bit set on the thermostat bolts. Lowe’s has a Kobalt brand which is decent. You want To get the bit firmly in the head socket then give it about 20 light raps with a small hammer. You are shocking the threads to loosen them up for removal. Don’t distort anything, just rattle their world a bit.
Do not put after market for Temperate sender unit. Put Genuine Volvo
Here it is
here is the thermostat
You will need a T40 to open the 2 screws on top of the thermostat housing unit. sometimes they are a bit*h to take off.
Here it is
1999 S-70 GLT @168K Miles
1987 740 GLE- Donated @215K Miles
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
I agree. Every single description and detail of the problem described by Kprixie happened to my former 98 S70 T5. At first I thought it was a head gasket also but before doing the work I replace the expansion tank and cap but the problem persisted. What I found was the thermostat was missing. The problem could be an opened thermostat so the temperature fluctuated even goong low then overheat (needle in red). I am not sure that it is truly overheating but you have to take the precaution thinking it is.scot850 wrote: 22 Aug 2018, 10:42 Thermostat sounds like a good probability as suggested above. Also check that the cooling fan is working.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Vernet or Wahler.Kprixie wrote: 24 Aug 2018, 14:09 ...Also does anyone know a good brand reliable for the sensor I can order myself online...
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Wahler IS OEM(read OE).RickHaleParker wrote: 24 Aug 2018, 18:12 I think Wahler is commonly used without problems, about $12
On original thermostat it's stamped Volvo AND Wahler....at least on EU market cars.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
