1999 s70 overheating in stop-and-go traffic
kumulipo
- Year and Model: 1999 S70
- Has thanked: 7 times
My new-to-me naturally aspriated 1999 s70 overheats in stop-and-go traffic. I can take heat out of the cooling system by running the heater on full, but its a drag on these warm days. Otherwise, the car stays at nominal heat while driving. Seems to me the problem is in the radiator shroud fan. Can anyone tell me at what coolant temperature its supposed to kick in? Flushing the system while I'm at it for good measure. Thanks!
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Sounds like your cooling fan is inop. With car on and in park, try turning on the AC and going out to see if the fan kicks in. Could be a bad fan, but more likely just a bad fan relay.
Do not let the needle ever go into the red on these cars. A little bump up from the 3 o'clock position is okay, but anything more and you could quickly be finding yourself with a blown head-gasket.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- Has thanked: 2197 times
- Been thanked: 1851 times
Could be a failed thermostat, bad ECT (coolant sensor), bad fan motor or an unlucky bad used relay. There is one other issue it could also be bad wiring on the ECT sensor at the connector by the power steering pump.
Hopefully not, but could be worst case the head gasket.
- 1599 Views
- 4834 Views
Last post by Amk20155
- 14 Replies
- 2108 Views
Last post by lcc014
- 2440 Views
Last post by jvl
- 1301 Views
Last post by VolvoCANBus
