2006 v70r iginition wires
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Year and Model: 2004 V70 2.5T
Been thanked: 472 times
Re: 2006 v70r iginition wires
Post by cn90 »
- Solder sometimes fail with constant vibration.
- Butt connector is bullet-proof, if done correctly.
- If you don't believe me, do a Google search using key words "car wiring butt vs soldering"...
Has thanked: 1507 times
Been thanked: 3822 times
Unless you are driving a Tesla in space, a good NASA solder splice is designed to withstand **some vibration***
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Pick n Pull is a good source. The same connectors work back to 99 s80, S70, V70, C70. 2000 to 2004 s40/v40 are not the same.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
The latest thing in "Butt connectors" produces ... gasp... a solder joint.
If solder joints where inferior, why would the "Butt connector" manufactures be going down this path ...
A solder joint spreads the stress from vibrations over a larger area. With a Butt connector all the stress is concentrated at the crimps, which are under stress to begin with. Think about it, butt connectors always fail at the crimp ... put two and two together.
[youtube][/youtube]
Post by cn90 »
- I have done hundreds of butt connections...zero problems in 20 years.
