Tailgate gasket 3512402 across top - shrinking? correct glue?
850forum
Year and Model: 1995 850 turbo wagon
Been thanked: 6 times
Post by 850forum »
Found some diagrams...
https://www.volvopartswebstore.com/prod ... 99177.html
18 Trim moulding, upper
windscreen drainage windshield, rear window and door windows 5DRS
3512402 $36.71
Also a glue kit - awfully expensive & it doesn't seem to be for this purpose:
Adhesive kit. Spoiler, boot lid, lip
Part Number: 31299177 ; 31298559
Your Price $ 49.75
NEVER OPEN THE HOOD !!!
Has thanked: 1609 times
Been thanked: 4064 times
Added part number to title for search...
850forum
Post by 850forum »
abscate wrote: 18 Sep 2018, 03:14 Added part number to title for search...
Well, that's my guess based on the diagram. If its the right diagram.
850forum
Post by 850forum »
Used Contact Cement. Used a toothbruse to scrub out the overflow, but I think I actually should add more so there is a bead instead of a trough where water could collect along the edge. Need to find something viscous in a tube with a small nozzle. Butyl seems right. Or more silicone caulk, as is already on the driver's corner.
Unsure if it is meant to be glued into the corners or if that's a drainage design. Guessing it should be sealed.
I can see that the top edge of the metal on the hatch is just beginning to seem rusty. Need to seal that with fingernail lacquer.
Also the Lower Moulding has gotten stiff & is coming away at the ends. Don't know if plastic revitalizer will help, letting it soak. Otherwise, it looks kind of generic as to its shape. Any ideas? Seems to be (expensive):
http://volvopartslisle.com/part/OEM-Vol ... ding-Lower
Diagram #19
Trim moulding, lower
Volvo Part: 9483520
$28.19
