2000 S70-The oil light comes on and goes off
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Asking about oil additives is basically just a can of worms. The general consensus is that if you know the history of your engine, and you run a quality oil, additives are probably not going to help much. In relevance to your oil pressure light, it could hurt, it could help, but we still don't know what's causing the light. If the light is on due to a blocked oil pickup screen or something, flushing the engine and loosening more deposits may not be such a good idea.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- Has thanked: 1611 times
- Been thanked: 4075 times
Just an oil change. It’s an unknown maintained engine so go slow. You don’t want to break lots of sludge free if it has been neglected. Oil and filter change, in about 500-1000 miles look at oil condition on dipstick and see How dirty it looks. Use synthetic oil too, maybe the cheaper synthetic blend if you think you will be changing it soon.
neworleans
- Year and Model: 2007 S60R
Hello all,
Here is the update.
I changed the oil and filter, the light never came on steady but blinked once for like less than a second. Hopefully it will never come back.
As far as the leak, I still see some oil dripping from the drain plug. I changed the washer when changed oil tough. Do you think a new drain plug will help?
Here is the update.
- 800 Views
- 1685 Views
Last post by SuperHerman
- 24 Replies
- 14741 Views
Last post by chrism
- 925 Views
Last post by GreenMagicMan
- 2010 Views
Last post by vtl
