If some of the seat motor functions work, it's almost ALWAYS the switch, they go bad.
Buy a used one at www.erievovo.com.
If the BACKREST is dead it's usually the cable that broke, (INSIDE the seat).
Power seat issue, switch or motor?
Volvo power seat issues: switch or motor?
Most likely you hear the motor running but there is nothing to actuate the movement of the seat-back, or in other words your cable is no longer working. Apparently, it's fairly common to have to replace the cable.
You could pull some DTCs from the diagnostic box under the hood. There is a procedure you could perform that will pull any existing codes, erase them, then search for and display all codes pertinent to your problem.
If the issue is the cable, then it is actually pretty easy to fix yourself. Sure, you'll have to take the seat apart, but if your confident in doing it yourself it'll save you lots of money compared with having a dealer fix it for you.
JRL
- Year and Model: Several
- Been thanked: 16 times
Fine, go find them (used) somewhere else, not so easy to dorwaltco wrote:Thanks for the idea.. I have found that Erie Volvo is ne of the most expensive places there is. Sorry Erie..thats the way it is.
VolvoBeginner
- Year and Model: 2002 S60 2.4T
Hi,ferrari9 wrote:Most likely you hear the motor running but there is nothing to actuate the movement of the seat-back, or in other words your cable is no longer working. Apparently, it's fairly common to have to replace the cable.
I just got my first Volvo ('94 850 Wagon) and the next day after I picked it up, drivers back rest adjustment stopped working. I could hear ruttling sound inside the back rest when I pressed the switch but it woldn't move. Next day I was driving it started moving down. Down only and I ended up driving like a "boy from the 'hood" with back rest reclined...
Today it started moving up but only a notch at the time, it feels like a relay beeing overloaded ;[
Does this sounds like a cable too? Or something else?
It will take me at least until next weekend to take the seat apart. I would like to know what am I looking for before I start. Are there any blue prints or manuals available on-line? I could not find any.
Appreciate any hints
and since it is my first post...Hello Everybody!!!
1994 Volvo 850 Wagon (N/A) - sold
1999 Volvo V70 (N/A)
VolvoBeginner
Thanks,JRL wrote:It's either the cable fraying or the gear splines breaking/broken
I found the replacement cable for $40+. But can not find any other spare parts related to this problem (splines?). Is there something like a gearbox?
Ronniedasaint
- Year and Model:
Where did you find the cable and were you able to work the problem out? If you did what did it require?
I was trying to adjust my seat today and it just started going down into "gangster lean". And it's really uncomfortable. I know this is pretty common because it happened in my last Volvo.
RonniedSaint
94 850 Non Turbo 2.4L
94 850 GLT
94 850 GLT
VolvoBeginner
I got it from here.
I did not replace it yet as the tranny leak was my priority. Taken care of yesterday
I will update the post as soon as I get to the seat problem. By the way playing Gangsta' Paradise goes really well with the seat position....
- 10476 Views
- 852 Views
Last post by draser
- 1922 Views
- 920 Views
Last post by MoVolvos
- 523 Views
Last post by the65dartguy1
