Power seat issue, switch or motor?
Volvo power seat issues: switch or motor?
bobsnow100
- Year and Model:
I would first check to make sure nothing un plugged under the seat.
If everything is still connected than either get a test light with a probe or a volt meter to test power at the motor. If there is power at the seat motor than thats the problem. Make sure you're pushing the seat button switch as your testing . If you're not holding the switch electricity will not flow through. If there is NO power than check for power going into the switch. If there is power at the switch ,probe the other wire coming out ot the switch going to the motor and see if you get a reading.
I am not sure if the seat motors are all on the same fuse either. Might want to check your fuses
I have the same exact problem with my 95 850. Everything works except the height adj at the rear of seat cushion. I retrieved DTCs that the wires to motors 1 & 3 are unplugged (which confused me a bit more since motor 1 is functioning as it should). I studied all the related documents provided in the service manual and by MadeInJapan about the seat components, wires, motors, etc. Upon examining the whole setup, I found that nothing seems to be unplugged.
When I press the switch I can hear the motor running inside the seat. Does this happen with your switch?
I've already spent enough money at the dealer trying to fix the entire seat (long story...). I'm going to have to take the seat out and really test everything. Sorry I don't have any other info at the moment but I'm very determined to fix this so hopefully I'll have some answers sometime soon. In the meantime, I'd suggest downloading the '95 850 Service Manual' (located at the very top of the 850 forum) which will have info pertinent to your model as well. There is alot of info in there about the power memory seats and I'm sure your's is pretty much the same deal as the 95s.
Good luck...
Good luck...
- Has thanked: 17 times
- Been thanked: 35 times
Seat switch contacts wear out...if you know how to take one apart, you can scrape the contacts with an emory board, but this may be a temporary fix. If you're hearing the relay, then it's getting juice, so then it may be one of the motors that's bad. Sorry I can't be more specific.
CarVolvo
- Year and Model:
it is the fourth motor that runs the rear seat movement. If you sit in the back seat on the drivers side of the car and remove the backing it is located on your right hand side in the seat backrest.
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
rwaltco...
The motor described by CarVolvo is actually the seat-back recline motor, located inside the seat-back. The motor that you are looking for is #3, which operates seat-cushion height at the rear. This motor is located under the seat. Grab a flashlight and take a look under there. You'll see three motors, one after another. Each motor looks almost like a red bull can - thin, cylindrical objects. Motor 3 is the last motor (if you are looking from the back seat, it will be the first one you see).
Hopefully this helps a bit...
Thanks for the correct info. I figured it was the recline motor since one is back/forward, one motor is for the front movement the last for the rear vertical. I think it must be the switch as now the forward/reverse is not wanting to work correctly unless I fiddle with it.
- 10468 Views
- 849 Views
Last post by draser
- 1904 Views
- 915 Views
Last post by MoVolvos
- 519 Views
Last post by the65dartguy1
