You can use synthetic to flush the old out (same amount as the regular method to get any old out) but that may not actually help your transmission. Sometimes when these get old, no amount of new/fresh fluid is going to help as your transmission might just be starting to give up its ghost. I'm very cautious to recommend a flush on a transmission that has never been flushed for instance, with high miles. However, you say yours has been serviced regularly. I don't agree that once synthetic, always so. I think that's an old wife's tale.
As for a non-turbo going synthetic (engine oil), I would say with those miles, if it ain't broke, don't fix it...just keep doing oil changes on a regular (3K miles) basis. The main reason for synthetic in a turbo is the coking that takes place in the turbo itself. Synthetic oil helps this issue much more than regular oil that can get hot and actually harden. Without a turbo, this is not as much of an issue.
Okay, all of the above said, are you getting any fault codes? Maybe there's another reason for the bad shifts....a PNP switch, cam position sensor, etc.
New Modified Transmission Flush Method with Pictures
- Has thanked: 17 times
- Been thanked: 35 times
wow, this was my first post here, you reply quick!
Thanks for the advice, I may give a shot at the trans flush with synthetic and see what happens. If it gets progressively worse - I have a parts car with a good transmission. Of course, I really really (really really) dont want to change the tranny.
The check engine light in the GLT has never come on, other than lighting up to show it works when you turn the car on, so I'm assuming no fault codes are present...
If its on the internet, it must be true!
'95 Volvo 850 TURBO - mileage: lotsa
Don't always assume no fault codes without a check engine light. Fault codes are stored once, sometimes twice and three times (depending on the issue) before they finally are consistent enough to light up the CEL. I would pull the codes anyway to see if you have any.
I'm assuming that I'd be checking the A1 codes, which only flashed back the 111 (no trouble, but you know that already). I also checked A2 but I'm pretty sure A1 is the tranny codes. A2 was also clear...
I did just pick up 8 quarts of synthetic atf, but havent changed it yet. Some guy at the auto parts store said to put in some lucas, but I tend to shy away from that kind of stuff.
any ideas?
any ideas?
Would be nice to have another 4 quarts. 8 quarts is what your transmission hold total...so to flush the old through, you really need more.
Oh, and don't use the Lucas...I'm convinced the stuff is snake oil.
OK, you talked me into it. I did the change last night and took a drive around. It did seem better but still not back to perfect. I'll see how the week goes!
Do you think that needing motor mounts could also be affecting my shifting? I know one is worn for sure, and a volvo guy said I actually need both front and one top mount.
Yes! If you need motor mounts you will feel a lot of jerkiness when the car shifts as well as vibrations at idle.
Ok, so add new motor mounts to the list, I might as well do them all I guess - there are two in front and one on top, right? I will say too though that the synthetic ATF made a huge difference, the car is shifting much much smoother now, which eliminates most of the jerk when shifting.
14Whittier
- Year and Model:
Have any experienced the frustrations of simply not being able to remove the hose to the radiator to attached the clear hose for the ATF flush? I am removing the lower hose facing firewall on the radiator (02 V70). These hose with the green simple clip mechanism just doesn't budget. Any suggestions or pointers ?
I soaked mine with PB blaster first and used snap ring pliers, and just moved the clip back on the hose, but I dont know if you have the same clip..
- 3014 Views
Last post by Pezgoon
- 1587 Views
Last post by Turbo_Boss
- 1301 Views
Last post by matthew1
- 14 Replies
- 5019 Views
Last post by firstv70volvo
- 1658 Views
Last post by MoVolvos
