2000 V70 NA Intake Air Temp Sensor? Not used on 20 V engine
cannuck
Year and Model: 2000 V70
Post by cannuck »
Still short on information and understanding. Is the IAT sensor included with the MAF???
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
No.
20v n/a cars have Maf.
10v n/a cars have IAT in instead of MAF...in the same place.
IAT is circled RED on the picture.
DOHC designation means 10v engine.
20v TURBO cars have both... IAT & Maf...plus MAP.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
cannuck
Post by cannuck »
Misha: Understand that, but what the heck is setting the P0113 code???
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 36 times
Post by crlande »
Could be a grounding issue. Check connection for corrosion. Disconnect and reconnect a few times sometimes cleans the connectors.
misha
Post by misha »
I would suggest to read the codes with Vida or go to Volvo dealer.
Scan all modules in the car for specific Volvo codes in ECM format.
P0 xxx format is generic and sometimes can't help with fault finding.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
misha wrote: 22 Dec 2018, 13:16 DOHC designation means 10v engine.
That's not right. DOHC means Double Overhead Camshafts. Our 20v engines are also DOHC.
- S
[Sold] '97 S70 T5
misha
Post by misha »
Right,they are both with double overhead camshafts...but every Volvo engine marked with DOHC instead of 20 valve indicates 10v engine in Volvo p80 world.
Others are marked with 20 valve.
That's the easiest way to tell if your Volvo is equipped with 10 or 20 valve engine,besides engine code on the block behind timing belt cover.
Canada have 10v cars while U.S market never imported those.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Sommerfeldt
Well, “DOHC” does not designate 10 valves. Those covers are completely interchangeable, so unless you know what the engine is or are completely sure that cover hasn’t been replaced over the last couple of decades, don’t trust that cover to tell you. And you wouldn’t need it to, if you already knew.
To check what engine is in there, use the engine code on the block, or peek in the ECU/TCU compartment and see what’s in there.
- S
[Sold] '97 S70 T5
misha
Post by misha »
DOHC designation on spark plug cover indicates 10v engine in p80 world.
If you can find a 20v car with DOHC designation on spark plug cover...i would like to see one.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Sommerfeldt
Point is, don’t trust a completely interchangeable spark plug cover to tell you what engine it is. “DOHC” means 2x overhead cams, and all our IL 5’s are DOHC. The “designation” applies to all of them - and trusting the spark plug cover (which could have been swapped out over the last 20+ years) is a bad idea.
Check the block or see what’s in the ECU box instead.
- S
[Sold] '97 S70 T5
