2002 V70 Front end troubles Topic is solved
MDK
Year and Model: 2004 S60R
Been thanked: 42 times
Post by MDK »
Thanks again abscate... I'll go with the lemforders. MDK
MDK
Post by MDK »
Well guys...MDK here. The problem was the nut holding the ball joint to the control arm was loose. I just left tire discounters and the mechanic unloosed it by hand. That's why it was so squirrelly on the road. .. ridiculous. MDK rolling on... over and out.
Has thanked: 1609 times
Been thanked: 4065 times
Yikes - thats quite a thing to leave loose....
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Really good to hear you find it and it didn't come out (I don't think it would come out while driving, the ball joint stud is long enough, but who knows)
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
The conical washer into aluminum knuckle comes loose if you don't counterhold the stud and tighten the nut. I've seen it on several brands using that arrangement.
This is coming back to me now. When I did my P2 clutch, I also did a FWB and removed the struts - I recall the nut needing countertorque to get to torque.
