How to make my V70 XC powerful?
- Has thanked: 316 times
- Been thanked: 531 times
First off, welcome!
I didn't read through the entire thread, but I'm just going to add my $0.02. 500-600 hp is a lot to ask out of one of these engines. You will undoubtedly need to tear it down and build it up to achieve this. Stock internals likely won't handle it.
Secondly, you will not be able to use an automatic transmission without a lot of fabrication work (read: a stronger transmission). Most of us performance oriented guys just manual swap, as these autos are good for about 300 whp (I don't know this from experience, this just seems to be the general consensus). Or in my case just because I hate autos!
As for the exhaust, do NOT dump it right below yourself. My cousin's V70 was like that when he picked it up and the drone was absolutely unbearable. It rattled your brain.
The closed/dummy muffler on the driver's side is stock for AWD models other than the 2000 R, that's just how Volvo made them.
There are no OBD2 "tuners" or "chips" that will work effectively for what you want to achieve. You'll need a tune from a reputable tuner like Va5t, iPd, or ARD.
Just like the transmission, a twin turbo setup will take a bit of fabrication. There is no bolt-on setup for these 5 cylinders. You'd be better off using a larger single turbo, probably some sort of Garrett with a custom manifold.
As for an intake, iPd makes one that has good feedback, but as with most intakes you're not going to net any significant gains in stock form. Slap-on cone filters aren't going to do much for you without a heat shield and some good ducting.
There's also the Simota CCI intake that ViVA sells. It's a little pricey, but it has good feedback. Both would pair best with Snabb's intake elbow for maximum flow.
You're not going to find a cheap intake unless you make one yourself.
I'm usually pretty optimistic, and I hate seeing people say "that can't be done" on threads like this (you can do anything you set your mind to, it's just a lot easier if you have deep pockets!) but these are big goals. If you're planning on using the car to tow a tiny house cross country (
) you'll probably want to either hold off or use a different car. Your best bet is to do a stage zero and enjoy the car. However if you really want to build something crazy, it can totally be done. You'll just want to do a LOT of reading.
I recommend checking out Volvospeed. A user "lookforjoe" built a V70XC that made over 400 AWHP, but it wasn't just a bolt-on matter. He used an M66 (AWD manual transmission). His build is well-documented, and I suggest you read through his posts. Another user named "Dougy" has (or had, not sure if he sold them yet) an 850 T5 and an S60R, both automatic, making something like 300-400+ HP and 600+ HP, respectively. I don't know exactly what he did to hold that kind of power on an automatic, but I'm sure if you look around you can find out.
Best of luck with your build, and keep us posted if you decide to go through with it!
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
Thank ypu so much very helpful!bmdubya1198 wrote: 15 Jan 2019, 17:40 First off, welcome!
I'm usually pretty optimistic, and I hate seeing people say "that can't be done" on threads like this (you can do anything you set your mind to, it's just a lot easier if you have deep pockets!) but these are big goals. If you're planning on using the car to tow a tiny house cross country () you'll probably want to either hold off or use a different car. Your best bet is to do a stage zero and enjoy the car. However if you really want to build something crazy, it can totally be done. You'll just want to do a LOT of reading.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Here’s “Look for Joe’s” trail of XR bread crumbs:
http://volvospeed.com/vs_forum/topic/11 ... try2231555
And an Excellent AWD component sticky from over at SS:
https://forums.swedespeed.com/showthrea ... s-Listings
- Has thanked: 2199 times
4 speed autos are rated to 320bhp. There is a guy in our province trying to sell a 400bhp 850 with an auto trans. I wish him luck!
I knew of an 850 (FWD) that had close to 500bhp, but it was built at huge cost for the owner by TWR in England. They ran the racing 850's and Arrows F-1 team as well as Jaguar racing. The engine had many custom parts including pistons. Hate to even think what it cost!
My 2000 V70R with the standard engine has been tuned by Rica software to supposedly run 312bhp and close to 300ft/lb torque. It goes well but again with auto trans and the AWD I expect some issues down the line!
- CIK7
Thank you again Neil!scot850 wrote: 15 Jan 2019, 19:40 4 speed autos are rated to 320bhp. There is a guy in our province trying to sell a 400bhp 850 with an auto trans. I wish him luck!
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
I second taking a look at those builds bmdubya mentions - the S60 “Dougy” at SS built (is building?) is insane, and there’s about a thousand pictures and a massive amount of info available.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
That car is for sale currently, so I guess "built"!Sommerfeldt wrote: 15 Jan 2019, 21:50 I second taking a look at those builds bmdubya mentions - the S60 “Dougy” at SS built (is building?) is insane, and there’s about a thousand pictures and a massive amount of info available.
- S
