No crank.
I got it to start again bit now it just cranks, doesn't turn. I did this by detaching the intake plastic cover t ge at faces the grill. Somehow that helped.
Does having 2 vaccum fuel hoses spilt prevent cranking?
Thank you
Cleaned ETM and now my 1999 S70 won't start
finestlittlemexican
- Year and Model: 1999 s70 T
- Been thanked: 4064 times
You have run out of battery. You need to get it charged overnight.
finestlittlemexican
okay, i found a connector under the air intake at the front of the grill that wasn't fulled snapped together, I think that fixed the non-starting. Now I've got bad idling again, but I think it's due to the 2 vacuum hoses were spilt. I couldn't trace the destination of the red stripe hose. Where is a hose diagram for the 1999 S70 Turbo?
Thank you everyone for your help
finestlittlemexican
I've got the 2 vacuum hoses fixed. one replaced to the purge valve connection and the other one was fixed by cutting it shorter to cut off the split portion. The idle is much better, but still a little rough. I wonder if the spark plugs are bad now.
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Just like the ETM cleaning, you’re jumping to conclusions without enough data.
Rough running is most likely to be vacuum leak, and not ETM or plugs. Spark plugs are pretty sturdy - their “natural environment” is pretty rough, remember.
Go over and replace your vacuum hoses, and reconfirm that all your various connectors are tight. Have someone read your codes if any, and post them here.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- 866 Views
Last post by precopster
- 1055 Views
Last post by jbkeene
- 2778 Views
Last post by Ozark Lee
- 13 Replies
- 2241 Views
Last post by TheRev813
- 11 Replies
- 2978 Views
Last post by oldironsights
