Check the MAF, it's free and easy to do and a good possibility.
Doesn't sound at all like a burnt valve. Vacuum leak also fits, have the lines ever been replaced or are they 20 years old?
'98 S70, 93k miles, intermittent Rough running and stalling Topic is solved
- Has thanked: 311 times
- Been thanked: 817 times
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
It’s also worth checking the fuel pump relay (as someone suggested) and fuel pump. Low pressure or unevenly operating pump will cause your symptoms, and probably not set a code that will stay until you get a readout.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Has thanked: 316 times
- Been thanked: 531 times
I wouldn't think it's a burnt valve, you'd definitely have a CEL and codes present. Plus, as it's been said already, these cars run fairly well on 4 cylinders. My cousin's S70 T5 even ran pretty well on 3 cylinders after we connected two of the coils backwards!
I'd say check the cam sensor and crank sensors, but I would recommend testing the MAF sensor as described first. I'd also try swapping the fuel pump relay or jumping it. It seems those will slowly fail in some cases, while other times they just go out and that's it.
1998v70xcbill
- Year and Model: 1998v70xc
- Been thanked: 3 times
check the coil.
fuel pump is usually ,no start
valves would not be intermittent. cam and crank you would think throw codes.
Cam and crank sensors are no-start, yes. Sometimes with a code, more often without because they get checked at startup and if the car won't start ...
Fuel pump relay is likely, pump relay and fuel pump problems can be no-start or they can be flaky, either way.
Not always. When my crank sensor went out, it was having these weird "hiccups" when I would start accelerating from a stop, almost cutting out. It was a little scary at times!
Eventually I got a multi-cylinder misfire code and a crank sensor code. Now this was the crank sensor, not the cam sensor, but to my understanding they present very similar symptoms.
Usually, but not always. I've had a bad/failing cam sensor without a code. Put in a newer used one and I haven't had any issues since. My car was having small little stutters here and there. Similar to, but not quite as severe as the situation I explained above when my crank sensor failed.
- utilityaudio
- Year and Model: '98 S70 GLT
- Has thanked: 36 times
*Ding Ding Ding* we have a winner.misha wrote: 18 Jan 2019, 13:57 Disconnect Maf connector,start the car and test drive it.If problem disappears...Maf is bad.
Other than that...could be a HUGE vacuum leak or FPR failure.
But,let's go one step at a time...cheapest things first!![]()
Mechanic finally got to my car, MAF was bad, didn't throw any codes.
also replaced the fuel filter for good measure. I'm relieved it's fixed, just wish it hadn't taken so long for them to work through their backlog.
going to try to sort through maintenance receipts from the PO, to look for Fuel Pump, relay, and Vacuum lines... if I don't find them I'll put them on my list of things to save up to replace.
Thank you to everyone who posted.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Keep the old Maf,just in case....because connector can also make problems.
I hope that you used oem Bosch maf #0 280 217 107 since aftermarket ones will not last....if work at all.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- utilityaudio
I'll ask.
- 1547 Views
Last post by oragex
- 7662 Views
Last post by enriquepr21
- 1716 Views
Last post by 240gator
- 797 Views
- 1140 Views
