Nope....you will need at least Vol-fcr.
Ecu M4.3 is practically obdI since it still produce flash codes along with ecc.
Other modules are fully OBDII including transmission.
Volvo S70 T5 automatic gearbox
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
I took the gearbox out and putted other clutch plats.....and put it back......but still slipping if i drive from brakpan to spings halfway.....when i turn eknision on and off again it sounds like a sollenoid is stil on.chould it do that
Also whant to know volvo automatic transmission 1998 S70T5 does the gearbox work whith bands inside or not.im planing to take out the gearbox tommorow i wich that i dont have to already done that twise now will be the thurd time
Hi Niel sorry for deley.i put dex twoscot850 wrote: 26 Jan 2019, 12:16 As the oil warms it starts to become thinner. Don't worry about the spelling as my Afrikaans is non-existent so I appreciate your helping me with english!!
From what I read above you have an auto trans (4-speed auto). I believe you have change the valve bodies possibly or do you mean the clutch plates in the trans itself?
How did you change the oil in the transmission? We always recommend you never use a machine and power flush these older cars as it tends to loosen the old dried oil from the inside of the casing and it gets into the valve bodies and clogs the valves which make the gears slip or not work at all.
What transmission oil did you use?
Is there anybody that can gif me advice on my volvo s70 t5 1998 automatic transmission please.its slipping.....i done few things but stil slipping after 1or 2 km of driving....then have to switch it of for few min then only can it go again
- Has thanked: 2209 times
Do you have the owners handbook with the car? I believed the correct oil for your transmission is Dex3 not 2.
