So far I broke 2 T55 torx bits both are 3/8 drive. Lisle 26650 T-55 Torx Bit Sockets
Next to find my T55 in a 1/2 drive..
These are not reverse threads Right? 3 ft breaker bar slow and steady upward motion. .. grrrr
2002 V70 xc. VVT Hub 5030523 9497786
precopster
- Year and Model: Lots
- Been thanked: 128 times
Have you got a cam lock attached to rear? Normal threads as far as I remember. A cheap set of Torx in a 1/2 inch drive will beat a good 3/8 but I guess it depends how cheap
mrjay62
- Year and Model: V70XC 2002
- Been thanked: 3 times
Gm Preceptor
Yes the Cams are locked.
I've had this Lisle set for 20+ years thought is was a good set used it last fall when I replaced the head on the car and one time before that when I replaced all the cam seals on the original engine head.
Broke one T55 Lisle then 1 from an old Craftmade set...I know I have another in 1/2 drive now to find it...
Just had to check and confirm that the threads are normal.
Thanks
Thanks
- 1900 Views
Last post by Mikaro07
- 1896 Views
- 8805 Views
Last post by dono
- 828 Views
- 5193 Views
Last post by LT South Africa
