Engine System Service Urgent
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
With your PCV system recently replaced chances are the fuel pressure sensor isn't connected properly. To service the PCV the entire fuel rail needs removal. Check that the fuel pressure sensor and all 5 injectors are tightly connected.
rphelan
- Year and Model: 2007 s60
- Has thanked: 2 times
I agree this would be wise. To be more exact, prior to the PCV service, the car "bucked" twice as I mentioned. Could this have been caused by a cracked upper breather hose from the PCV? I didn't think it was.
These 2 occurrences were much rougher than what I am currently experiencing with the acceleration. And on one of those occasions the check engine light flashed but did not stay on. The mechanic that performed the PCV replacement also told me that there was an old code related to fuel pressure. Which he cleared. My mistake for omitting that detail which is important.
I ordered the fuel pressure sensor. The shop I took it to today told me the fuel pressure sensor was installed properly at present. He showed me how to disconnect it and how to install a new one which I reviewed again on YouTube. I can handle that. Not sure I would know if the injectors are tightly connected. I think that would require taking off the fuel rail, correct? Any links to video would be appreciated as this is new to me.
Frenchflacco
- Year and Model: 2006 volvo
Yo same situation but my code came back as loose gas cap. Weird how same symptoms but different things.
- 4186 Views
Last post by earthworm
- 8263 Views
Last post by precopster
- 3119 Views
Last post by jbkeene
- 1901 Views
Last post by lpl258
- 24 Replies
- 10577 Views
Last post by SVO LOU
