follow-up to my follow-up:
The butterfly valve appears ever-so-slightly open. Is this supposed to close down completely?
P2111 After O2 Sensor Replacement
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
It stays slightly open for air while idling. There is no idle air control valve on theses 2.5L engines.ChrisRicc wrote: 07 Apr 2019, 16:21 follow-up to my follow-up:
Had the same question myself when I first dropped the ETM. I installed a new Bosch ETM last December and the valve on that unit is nearly the same as the defective unit.
EngineeringBloke
- Year and Model: 2006 2.5T S60
- Has thanked: 57 times
- Been thanked: 39 times
There is more than enough gunk in there to account for the throttle plate to jam or stick.
I am certain that you could clean it and I would expect the throttle body to work fine after that.
Perhaps, after the O2 replacements, the system saw the oxygen level more accurately and had a greater need to close the throttle - hence the plate closing on the junk.
I also installed a new ETM (non-Volvo, non-Bosch) and found it and the original had a spring that pushed the plate to almost closed, and another spring that opened the plate from fully closed to the slightly open position. I also concluded this was the idle air feature.
I was trying to understand why my ETM only closed to 10% tracked via my Torque app. However, the new one has the same behavior.
ChrisRicc
- Year and Model: 2004 V70R
- Has thanked: 3 times
Thanks, XC70Rider and EngineeringBloke. Both posts have been very helpful. I did go ahead and clean the unit in the pic. I haven't reinstalled yet, but it came pretty clean... amazingly. I'll pop a new gasket on there and hook her back up this week. I'll follow up with hopefully an all is well post. I can't remember if I heard it here, but removing the cooling fan helped immensely accessing the ETM. Incidentally, I did wonder if the replacement of the O2 sensors did require different activity from the ETM that it couldn't accommodate in its mucked up condition, which then threw the code that shut down the car. I just don't have the experiential intellectual archive to say definitively on my own.
Curious - in removing the wiring from the ETM, the connector shattered in my hand. Is there a fix for this, or am I forced to rig an alternative?
- RickHaleParker
- Been thanked: 978 times
That may of been all or part of the problem all along. See my post on page one. Follow the link below.ChrisRicc wrote: 07 Apr 2019, 21:41 Curious - in removing the wiring from the ETM, the connector shattered in my hand. Is there a fix for this, or am I forced to rig an alternative?
No time wasted, cleaning the ETM is not a waste of time.
Repair Harness for Volvo Electronic Throttle Body
Active
Past
Past
- RickHaleParker
I cannot answer that because the description does not sound scary to me.
If the rest of the harness is in good shape you have an alternative.
Get a set of Pin extraction tools, go to a PnP extract the pins from a connector, then install the plastic connector on your old harness.
If you go to a shop that specializes in Automotive electronics, there is a good chance you can buy a new plastic connector or hire them to install one. The bill should not be much.
Active
Past
Past
XC70Rider
After breaking that same connector I installed a new 31409380 Harness myself. I didn't splice the wires but replaced them all leading back to the ECM. I got this aftermarket ECM extractor tool for less than $12 and it worked fine.
https://www.ebay.com/itm/Pro-ECU-comput ... 2749.l2649
ChrisRicc
I think there's one included in the harness kit RickHaleParker referenced in the post above for $40 total. XC70Rider, was the install of the new harness at the ECM a relatively straight forward task?
- 2034 Views
Last post by jimmy57
- 3277 Views
Last post by mrbrian200
- 3062 Views
Last post by RickHaleParker
- 3034 Views
- 18 Replies
- 20140 Views
Last post by doublebug
