Pull off the cap and rotor and clean them up and get a good spark
If you get a good spark and it won’t fire on ether, part it out or get a new engine
1994 850 N/A Manual won't start
- Has thanked: 1611 times
- Been thanked: 4072 times
Aheadbeyond
- Year and Model: 1994 850 N/A
Didn’t mention this. New cap and rotor was the first thing I did. Gapped all the plugs at .028 and had good spark on all 5
- RickHaleParker
- Been thanked: 980 times
You spray starter fluid in Air intake not the cylinders. By the time you get the plugs back in and the wires reconnected the starter fluid would be long ago dissipated.Aheadbeyond wrote: 07 Apr 2019, 16:56 Pulled spark plugs put some stater fluid in. Didn’t even sputter.
Spray a three second burst of Starting fluid in the Air Intake hose, then crank immediately before the Starting has a chance to dissipate.
Active
Past
Past
- misha
- Has thanked: 155 times
- Been thanked: 432 times
This ^^^.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Aheadbeyond
I tried this on my initial no start condition. I tried thru the spark plugs because it was suggested on an older post for a no start. I did spray it into the cap and poured it. But I will follow the suggested procedure now that I have gapped all the plugs to spec.
Just to verify.028? They were all at .040
Wanted to say thank you to everyone for their help.
Troy
Troy
0.028 inches , correct
