The balancing lines where still leaking after the O-ring replacement. Spend 1.5 day swapping the hard lines. The sub frame had to be lowered approximately 5 -8 inch, steering rack can stay in place to replace these hard lines. Front suspension too, I only disconnect the steering arm from the knuckle.
No luck still leaking. Looks like the o-rings are not being compressed enough. Tried putting a washer behind the collar of the hardline but still leaking.
Has anyone else experienced this?
2006 V70 2.5t power steering rack leaking slowly
Rvolvos
- Year and Model: 2006 xc70
- Has thanked: 73 times
- Been thanked: 23 times
- B28D7B87-08C4-4F29-A5DC-E49819FE2E81.jpeg (119.81 KiB) Viewed 1832 times
- B6190AB8-78C4-4215-A1AE-A0877E3F2DCD.jpeg (128.41 KiB) Viewed 1832 times
- C22F72A9-8076-40B3-8B0B-3189D5193E0B.jpeg (145.67 KiB) Viewed 1832 times
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2011 C30 T5 M66 105k Totalled RIP
2006 V70 2.5T 184k RIP
2011 C30 T5 AW55-50SN 99k sold
2012 S60T6 95k rip
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
I just replaced my steering rack with a used unit. Its actually not a bad job. One thing suprised me was one connection was finger tight but not leaking (assume low pressure) i re-used the o rings and they dont appear to be leaking. Only thing i regret doing is allowing the oil to seep/drip into the sub-frame causing it to appear like a leak after fitting the replacement rack. Anyway got it all cleaned up now and just need to drive it too check any leaks/ive ordered new o rings in case.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
v70waggin
- Year and Model: 2005
- Has thanked: 3 times
Facing the same problem
Glad I'm not alone, did you ever figure this out @rvolvos?
So far I replaced the o-rings twice, it leaks even at idle without any steering load or input.
The leak originally started or was noticed after a small impact that broke the inner tie rod.
I replaced the tie rod and got an alignment, the car drove without any issues after topping off fluid, used a few oz every 100 miles.
Any advice would be greatly appreciated.
Oro
- Year and Model: V70 XC, XC70+S60 awd
- Has thanked: 7 times
- Been thanked: 37 times
I stopped a slow leak on a Lexus by adding ester oil to condition seals. Worked great. I used Lubegard PSF. You can try their additive (transmission additive (red) is fine to use, not really any different in this regard than their dedicated PS additive). They make PSF, too, but pricey. Redline PSF or AT fluid should also be ester based and achieve the same effect.
v70waggin
Guessing you didn't read the thread @oro ?Oro wrote: 14 Jul 2024, 16:12 I stopped a slow leak on a Lexus by adding ester oil to condition seals. Worked great. I used Lubegard PSF. You can try their additive (transmission additive (red) is fine to use, not really any different in this regard than their dedicated PS additive). They make PSF, too, but pricey. Redline PSF or AT fluid should also be ester based and achieve the same effect.
Both the OP and myself replaced the seals, sometimes twice.
Oro
You replaced every hose and seal?v70waggin wrote: 14 Jul 2024, 20:03Guessing you didn't read the thread @oro ?Oro wrote: 14 Jul 2024, 16:12 I stopped a slow leak on a Lexus by adding ester oil to condition seals. Worked great. I used Lubegard PSF. You can try their additive (transmission additive (red) is fine to use, not really any different in this regard than their dedicated PS additive). They make PSF, too, but pricey. Redline PSF or AT fluid should also be ester based and achieve the same effect.
Reason: edited for politeness
v70waggin
I correctly traced the leak to the hard/transfer lines beyond certainty.
If new o-rings couldn't stop the leak, pretty certain "stop leak" won't.
I'm guessing it may be a clog in the system or PS pump is putting out too much pressure. Unsure how to test
Only have ever ran the recommended CHF202 at regular intervals and believe the previous owner has as well.
- jonesg
- Year and Model: 2004 V70
- Been thanked: 532 times
is it the unions or the hard line that leaks.v70waggin wrote: 15 Jul 2024, 10:18 I correctly traced the leak to the hard/transfer lines beyond certainty.
I'm guessing it may be a clog in the system or PS pump is putting out too much pressure. Unsure how to test![]()
its a huge hassle but it would be easier to zero in if you pull the rack and lines,
then sit the rack on top of the engine and hook the lines up.
its much easier to examine if you get it in your hands.
v70waggin
jonesg wrote: 15 Jul 2024, 20:40I'm thinking its not the hard-lines, about 99% sure because :v70waggin wrote: 15 Jul 2024, 10:18
1. Its a California car, no corrosion
2. the transfer lines are attached to the rack, not much movement. I would think the supply line would blow first.
3. Most importantly Rvolvos, the OP installed new genuine Volvo/ZF lines and the problem continued, sent Rvolvos a pm to see if he ever found the root cause.
- hiroku
- Year and Model: 2002 V70 T5
- Has thanked: 21 times
- Been thanked: 9 times
Hijacking this thread, since it didn't seem worthy of creating a new one.
My 2002 T5's power-steering is a leaky mess, so following the good advice on this forum I'm upgrading the reservoir and suction hose to the 2005-plus ones. But part of the damage is already done, and I'll need to spring for a new power steering pump as well.
Wondering what manufacturers people recommend? On the P80 platform it's pretty well catalogued which manufacturer supplies which parts that come in the OEM box, but can't seem to find the same information for the P2.
OEM Volvo is prohibitively expensive, and even decent aftermarket brands like TRW or Bosch are over 300€ without the core charge. I didn't want to fit a crappy 100€ pump off Auto-Doc and have to replace it again next year either, but seeing as the root problem that kills these pumps (crappy reservoir design) is being fixed, maybe a cheap part will last forever?
I'm a pretty indecisive individual, if you couldn't tell already.
Thanks!
Thanks!
- 3717 Views
- 737 Views
Last post by MoVolvos
- 305 Views
Last post by Scruffy
- 1093 Views
Last post by sleddriver
- 30 Replies
- 27042 Views
