Good Morning All-
I've had a power steering fluid leak over the past several weeks and assumed it was the rack. A peak under the car revealed the leak is actually coming from the flex pipe section of the hose. The hard line is still in tact.
I followed it to the top of the rack and honestly, I don't want to disturb it on that end since its not leaking and I feel like if I do, I'll create more problems that I solve. I've heard these rack suffer from galvanic rust, not to mention the rack side fitting is in an awkward position.
Has anyone had experience splicing the hardline with either a generic one with a flex line, or even just splicing a hard line with a loop bent in to allow for flex? The car only gets driven about 5K a year at that, so the wear and tear will be minimal.
The car- 1999 S70 145,000 mi
1999 Volvo S70 Power Steering Hose Leaking (Repair to line without messing with rack) Topic is solved
I recall you are pretty handy so Ill offer this route..
Typical power steering pump relief valves pop at 1500psi, and an SAE 45 flare fitting has a working pressure of something like twice that (from a recent project)
I think you could make up a flare - pipe -flare pretty cheap that would save you from messing with the rack fittings.
If there is room, you could roll a helix into it for strain and vibration relief - obviously right hand helix in the Northern Hemisphere
volvooh
- Year and Model: '98 S70, '05&'08 V70
- Been thanked: 4 times
Thanks, Abscate.
I see in addition to my power steering leak I appeared to have posted in the wrong forum! I see I posted in the 2001+ crowd.
I got that idea recently when my clutch hose running between my MC and SC blew out through the flex (Not a Volvo, a Saab). I was a little concerned about finding a reliable replacement due to the Mfg discontinuing production and messing with the slave connection (again in a very awkward location). I was looking at splicing in a section of hard line with a couple loops built in to absorb the flex.
I ended up finding an original saab part and replaced it, but considering the miles driven yearly I'm thinking the wear and tear to be minimal. Honestly, I drove around a bastardized set-up in a land cruiser for 5 years the previous owner had rigged a P/S cooler by cutting the line, and connecting the cooler with what looked like either heater or fuel hose, then securing the whole thing with screw clamps. It wasn't a perfect set-up as a couple of -10 F days I blew the connection on start up and had to re-fill and re- bleed the system. My solution...I added an additional screw clamp on the second blow-out. Lasted till I sold it. Who knows now!
volvooh
I just wanted to follow-up on this. I was successful in replacing the leaking flex pipe with a 3/8" hard line. Using a normal pipe cutter and a rented flange and bending tool from at autozone, and lots of elbow grease, I got it done. For anyone attempting this fix, be advised the hard P/S line is a hair bigger that 3/8, so it does require some grinding and sanding of the existing hard line in order to slide the nut on the line and back far enough to allow for the flange tool. I added an extra couple of bends to give it some flex.
The car is only driven about 5000 mi per year, so I am comfortable with this repair...if this was a true daily driver do 20,000 mi, I'd probably opt to do the flex line.
And will move this to the P80 Forum in 5,4,3,2,1....
Last bumped by abscate on 05 Dec 2020, 15:01.
- 21 Replies
- 7918 Views
Last post by foggydogg
- 406 Views
Last post by itsmekirby
- 19 Replies
- 6594 Views
Last post by hiroku
- 739 Views
Last post by MoVolvos
- 306 Views
Last post by Scruffy
