Persistent misfire Topic is solved
shegarty
Year and Model: 1998
Has thanked: 12 times
Been thanked: 8 times
Post by shegarty »
Thanks for all the suggestions ... upon even further investigation it appears to be an intake gasket failure at cylinder #1, and possibly a leak around the aforementioned vacuum elbow. I'll know more once I get the intake removed. Parts are on order but since I live in the great white north it will be a week or so before they get here - we seriously need a better option for decent parts in Canada.
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
Has thanked: 1610 times
Been thanked: 4069 times
RickHaleParker wrote: 07 May 2019, 16:19 I missed the '98.
Could be a intake manifold gasket leak at #1. Fire it up and spray some starting fluid around intake manifold port #1. If there is a intake manifold gasket leak at #1, it will suck in starting fluid and you will hear the engine surge. If it does surge, let it scare you and back off on the starting fluid.
Lower compression at #1 could be the cause also.
Another set of Volvo horns for Ricks’ shelf, laurels, and accolades; an event worthy of a semicolon.
