[S60 2.0T 2006] Oil leak near turbo Topic is solved
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
adrian121,
Your PCV system is clogged thus the glove inflating.
What is the mileage (miles or km) in your S60?
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
adrian121 wrote: 13 May 2019, 23:41 What do you think?
It is a fail. That is negative crankcase ventilation, it should be positive crankcase ventilation.
Active
Past
adrian121
Year and Model: 2006 S60 2.0T
Has thanked: 2 times
Post by adrian121 »
It's been I while since last update.
There were an issue with PCV. I redone the whole system again and also changed PCV hoses near turbo - now it works like a charm.
Thank you @vtl and @abscate.
Unfortunately, oil leak near turbo is from head gasket. It was confirmed by two workshops. Leakage is not a big one and I need to choose between:
- leave it like it is and repair head gasket (and the engine) in the future
- replace head gasket
- change the engine
I am taking into consideration to replace head gasket by myself after winter.
Car is locked in the garage, for now.
