I replaced the MAF sensor. Seems to be running a bit better, but think I need to drive it for a bit to either reprogram the computer or wait for the code to come back. I am thinking the faulty MAF may have lead to the low fuel pressure. However I do have a fuel pump coming in the mail. The car has over 200k miles, and hasn't had the fuel pump done since at least before 65K. Where is the PEM located on a 04 S60 2.5L Turbo? It is not in the trunk like some other models. Is it accessible, or do I need to drop the tank?abscate wrote: 30 May 2019, 04:45 Try the PEM first. The definitive way I see to check fuel pressure with a gauge. I don’t like that reading of 7 psi though, I don’t think the car will run at that low pressure?
High Fuel Pressure? Leaky Injector? Or something else.
JohnnyBee323
- Year and Model: 2004 S60 2.5 T FWD
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Continue monitoring STFT and LTFT.JohnnyBee323 wrote: 30 May 2019, 09:02 I replaced the MAF sensor. Seems to be running a bit better, but think I need to drive it for a bit to either reprogram the computer or wait for the code to come back. I am thinking the faulty MAF may have lead to the low fuel pressure.
Originally PEM was located near the fuel filter. It feels bad being there, Volvo even released a PEM relocation TSB.JohnnyBee323 wrote: 30 May 2019, 09:02However I do have a fuel pump coming in the mail. The car has over 200k miles, and hasn't had the fuel pump done since at least before 65K. Where is the PEM located on a 04 S60 2.5L Turbo? It is not in the trunk like some other models. Is it accessible, or do I need to drop the tank?
Fuel pump dies when duty cycle reaches 55-60+ %. New pump should read about 35%. Mine is 45% in summer and 50% in winter, at 248k miles.
I would also replace at least the front H2OS. They work for 10-12 years and get "dull".
JohnnyBee323
Mine is a turbo, and read that 55-60psi is normal for a turbo. That's in the ballpark of where I am according to the scanner. Is that not correct? On cold start ups is when I am having the issues with fuel pressure, but at the moment it seems the new MAF sensor is improving that. Too early to tell.vtl wrote: 30 May 2019, 09:20Continue monitoring STFT and LTFT.JohnnyBee323 wrote: 30 May 2019, 09:02 I replaced the MAF sensor. Seems to be running a bit better, but think I need to drive it for a bit to either reprogram the computer or wait for the code to come back. I am thinking the faulty MAF may have lead to the low fuel pressure.
I replaced the 02 sensors not too long and fixed all the vacuum leaks. Would I get a code for a faulty PEM? I am receiving nothing for a fuel pump.
vtl
In B5254T2 fuel pressure is 400 KPa, which is 58 PSI. It does not deviate much from this number.JohnnyBee323 wrote: 30 May 2019, 09:38 Mine is a turbo, and read that 55-60psi is normal for a turbo. That's in the ballpark of where I am according to the scanner. Is that not correct? On cold start ups is when I am having the issues with fuel pressure, but at the moment it seems the new MAF sensor is improving that. Too early to tell.
I don't think there's a code for PEM. PEM is like an amplifier with no feedback.JohnnyBee323 wrote: 30 May 2019, 09:38 I replaced the 02 sensors not too long and fixed all the vacuum leaks. Would I get a code for a faulty PEM? I am receiving nothing for a fuel pump.
JohnnyBee323
Right. It consistently stays at about 400 KPA. Seems to oscillate a little bit between 399-402. Not much more than that.vtl wrote: 30 May 2019, 09:43In B5254T2 fuel pressure is 400 KPa, which is 58 PSI. It does not deviate much from this number.JohnnyBee323 wrote: 30 May 2019, 09:38 Mine is a turbo, and read that 55-60psi is normal for a turbo. That's in the ballpark of where I am according to the scanner. Is that not correct? On cold start ups is when I am having the issues with fuel pressure, but at the moment it seems the new MAF sensor is improving that. Too early to tell.I don't think there's a code for PEM. PEM is like an amplifier with no feedback.JohnnyBee323 wrote: 30 May 2019, 09:38 I replaced the 02 sensors not too long and fixed all the vacuum leaks. Would I get a code for a faulty PEM? I am receiving nothing for a fuel pump.
But if the fuel pressure is as low as 7 psi at the rail on startup, would that indicate a weak pump in your opinion or a PEM? Especially if the FRP is consistently at 400~ KPA while running?
vtl
Let the key stay in position II for a second before cranking the engine. Those late fuel systems with no return line have some sort of a morning pressure buildup lag.JohnnyBee323 wrote: 30 May 2019, 09:55 Right. It consistently stays at about 400 KPA. Seems to oscillate a little bit between 399-402. Not much more than that.
- Has thanked: 1611 times
- Been thanked: 4073 times
There is a spec of fuel pressure 20 minutes after shutdown, but no spec on cold start up, so It could bleed to zero.
In the XC90 forum, there is a detailed link to PEM waveforms by user shockwave who diagnosed a nasty fuel problem from a kinked line.
The MAF is completely independent from fuel pressure.
JohnnyBee323
I have tried leaving the key in the II position thinking it would help, but nothing as of yet. Why would the engine surge up and down for about a minute straight on a hot day when starting up the engine? This is the same problem I am attempting to describe, but much worse it seems on hotter days.vtl wrote: 30 May 2019, 10:03Let the key stay in position II for a second before cranking the engine. Those late fuel systems with no return line have some sort of a morning pressure buildup lag.JohnnyBee323 wrote: 30 May 2019, 09:55 Right. It consistently stays at about 400 KPA. Seems to oscillate a little bit between 399-402. Not much more than that.
vtl
How old are the spark plugs? Are they Volvo original (our turbo often dislikes aftermarket spark plugs)? Tightened to the spec? Coil packs sit tight and torqued to the spec, ground contacts are clean on both the valve cover and the pack?JohnnyBee323 wrote: 30 May 2019, 10:42 I have tried leaving the key in the II position thinking it would help, but nothing as of yet. Why would the engine surge up and down for about a minute straight on a hot day when starting up the engine? This is the same problem I am attempting to describe, but much worse it seems on hotter days.
People often/usually miss that coil pack high-voltage ground contact and fight for ever with misfires, bad sparks and prematurely dying coil packs.
JohnnyBee323
I purchased the car about 10,000 miles ago. The previous owner, a friend that didn't take care of the car, said he installed cheap aftermarket spark plugs in the car shortly before I bought it from him. How would your turbo behave with aftermarket spark plugs?vtl wrote: 30 May 2019, 11:21How old are the spark plugs? Are they Volvo original (our turbo often dislikes aftermarket spark plugs)? Tightened to the spec? Coil packs sit tight and torqued to the spec, ground contacts are clean on both the valve cover and the pack?JohnnyBee323 wrote: 30 May 2019, 10:42 I have tried leaving the key in the II position thinking it would help, but nothing as of yet. Why would the engine surge up and down for about a minute straight on a hot day when starting up the engine? This is the same problem I am attempting to describe, but much worse it seems on hotter days.
- 21 Replies
- 2565 Views
Last post by RedBrickCollector
- 15 Replies
- 7103 Views
Last post by sjanssen15
- 44 Replies
- 7022 Views
Last post by logscool
- 1608 Views
Last post by bugeye
- 12 Replies
- 5629 Views
Last post by darrylrobert
