Short to ground... where is it? Fuse 11A/8 Topic is solved
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
abscate wrote: 10 Aug 2019, 03:35 I think that’s the mode where the car tries To lock doors but sees one of them I see open.
It does point to a wiring fault somewhere, but not necessarily in the door moving
Maybe it's the tailgate latch? I know it's bad, I have to slam it sometimes 5-6 times before it latches properly. The trunk area light also doesn't work, because that circuit passes through the latch.
Has thanked: 1610 times
Been thanked: 4065 times
Oh yeah. That’s it.
If you strip open the wiring loom in the left tailgate hinge Area , you will find broken wires.
That can also short out your central locking which then takes out the immobilizer.
Search forum for “1999 Oneonta” for pictures
bmdubya1198
Yeah, I had that harness apart once already to fix my center brake light... it seems that was the only wire that was actually broken, believe it or not! I've been waiting for a good latch to appear at the junkyard.
