Given the choice between magic or physics, I give the edge to physics.MarkG wrote: 21 Jul 2019, 20:10 ... -How did I not overheat and have damage when I lost all that coolant when the heater core failed, and I drove almost 5 minutes after the low coolant light went on ?- ...
That is, I wouldn't consider the fact that the car didn't overheat as evidence of some miracle, but of the simplest explanation: there was enough coolant in there to protect it.
The light first comes on when the coolant level approaches the bottom of the reservoir, not when the system is empty. Obviously, the light coming on doesn't mean the same thing in every case. So, it doesn't mean the system emptied catastrophically for you, just that at that moment it was low. Maybe it started as a slow leak, and got much worse about when or after you stopped the car. The heater core likely continued to leak while you were walking to the station and back, and over the 40 minutes of miscellaneous filling. You added liquid into a hot engine, it emptied to the carpets, you put in more.
I wouldn't advocate anyone drive 5 miles with a sudden onset low coolant light, but it seems to have worked out for you. Three cheers!
