Right...
I have physical AUX input (hole) inside the center console under my armrest. It was a working function in the display with my old head unit before it quit working.
The new (used) head unit that I installed does not show AUX in the display as an option as I cycle through the Sources.
So I guess basically my question is are all HU650s the same and the AUX can be enabled and disabled OR do some HU650s have AUX and others don't.
WTF is up with my Radio
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
I'm not sure if this means there is a high performance unit?
https://accessories.volvocars.com/en-se ... 25613/2005
I think you'll have to go this route 2 videos - although the link below said this did not work so had to use something else
EDIT:
Bohdan Artymovych 1 year ago
How did you do it, please help, I tried the grom unit and an eBay unit and no luck
Darko 1 year ago
Hi, you need Arduino controller (Uno, Nano, etc. )and few cables. The sequence is written here http://gizmosnack.blogspot.fi/2015/11/a ... radio.html
http://gizmosnack.blogspot.com/2015/11/ ... radio.html
EDIT:
Darko 1 year ago
- MoVolvos
HU-650, radio
Integrated CD player
Simple menu navigation
18 FM/12 AM presets
Direct buttons for FM, AM and CD
6 direct buttons for radio channels
Digital signal processor for improved audio performance
World tuner for FM and AM band with RDS/RDBS
Control for external CD changer for 10 discs
Prepared for Sirius satellite radio (US only)
Prepared for AUX (from w0648)
HU-650, radio
18 FM/12 AM presets
sixspence
- Year and Model: 2007 XC70
- Has thanked: 5 times
THIS RIGHT HERE from your video.... THIS is what I don't have.
I do not have AUX as an option in the Source selections.
ALSO... This is an interesting bit of info from your Volvocars.com link
"Prepared for AUX (from w0648)"
What is "from w0648" ?
MoVolvos wrote: 30 Jul 2019, 22:16 -
Darko 1 year ago
- MoVolvos
I did a search with w0648. Can plug in your vehicle info to see what comes up?
https://www.volvopartswebstore.com/prod ... Term=w0648
- MoVolvos
[quote=sixspence post_id=514521 time=1564547331 user_id=101837]
[quote]
From everything I've seen I still can't figure out if that is built in and displays after you have something hooked up to it OR it's a different unit altogether?
[quote]
- MoVolvos
Will catch up with you later. Perhaps someone else will chime in tomorrow.
- MoVolvos
OK, one last interesting for now. Different part numbers so going to assume two different units with the same model number.
Exchange hu-650
AUX CH 644752- EXCH FOR 31260000, 31260310 (36002273) (8103771)
W/O AUX CH 502868-626605 FOR 31260304, 31260267 (36002272) (8103770)
https://www.volvopartswebstore.com/show ... ct=9956241
Exchange hu-650
sixspence
I think you nailed it.MoVolvos wrote: 30 Jul 2019, 23:02 -
Exchange hu-650
Oddly, the unit with the AUX channel is cheaper.
- 511 Views
Last post by Ozark Lee
- 14 Replies
- 2751 Views
- 1061 Views
Last post by shiloh51933
- 11 Replies
- 10675 Views
Last post by JRL
- 4201 Views
Last post by 850TurboTurtle
