What LED headlights do people use in their Volvo
Has thanked: 1613 times
Been thanked: 4078 times
DRLs are how the Communists contaminate our precious bodily fluids , purity of essence.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Rattnalle wrote: 29 Jul 2019, 01:41
MoVolvos wrote: 28 Jul 2019, 22:36 What is a "can-extender" and how is that wired into the fog lights. It would be brighter for sure to run those as the DRL.
A little data box that hijacks the can network signals and adds to them in different ways.
Can ( :roll: ) you send a link to can-extender? Thank you.
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
MoVolvos wrote: 29 Jul 2019, 19:51
Here you go: http://www.auxadapter.se/?page_id=36
MoVolvos
Post by MoVolvos »
Thanks Rattnalle for the info. I don't think we have that here in the U.S.
reverend
Year and Model: 2006 V70 2.5t
Has thanked: 2 times
Been thanked: 3 times
Post by reverend »
The only options were halogens, reflector HIDs and the projector HIDs on these cars. There are no LED options.
That wouldn't have stopped some idiot from sticking the LED "conversion bulbs" in there, but your pattern will always be poor and unless you drill the shunt, you'll have the bulb out warning in the dash.
I'd go back to proper OEMs, even if they're not the most exciting option. Or get some ABLs, but the cost of them is appalling.
MoVolvos
Post by MoVolvos »
reverend wrote: 31 Jul 2019, 10:55 The only options were halogens, reflector HIDs and the projector HIDs on these cars. There are no LED options.
If the OE is halogen the LED's should be a direct fit. Some have better pattern than others but they do light up the road much better except against asphalt.
Rattnalle
Post by Rattnalle »
MoVolvos wrote: 31 Jul 2019, 20:45
Exept the beam pattern never seems to actually match perfectly, leaving a glaring headlight.
reverend
Post by reverend »
Yeah, they'll FIT by virtue of being illegal. Basically, there are tight specs for an H11 or H9 (or any other) bulb. None of them allow for various filaments and light emitters. The reason they're illegal is because of their sub-par/dangerous/poor pattern.
A headlamp is a precision engineered piece of safety equipment where bulbs need to be made to an exacting spec and for housings and reflectors/projectors that are also made to tight tolerances to put the light where it needs to be and not blind others.
By sticking LEDs inside of a reflector made for halogen filaments, or any other combination, you've effectively degraded the output and put others (and yourself) at risk.
None of them have better pattern than the bulbs engineered for the housing. None of them light up the road better ("better" meaning that you see more without blinding others).
For the P2 cars there are very few solutions, but one of them is to get European OEM housings. That allows you to use the H7 bulbs instead, which opens up a wider variety of bulb options. None of which should be entirely coated in blue, btw.
Rattnalle
Post by Rattnalle »
This is all for low beams though. The high beams can be improved by using after market xenon out LED bulbs. Still not legal in most places though, here we get away with it.
MoVolvos
Post by MoVolvos »
Rattnalle wrote: 02 Aug 2019, 00:39 This is all for low beams though. The high beams can be improved by using after market xenon out LED bulbs. Still not legal in most places though, here we get away with it.
What is a xenon out LED bulbs?
