Aw55/50SN. Swaping transmission? Will it work?
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
I think there were 2 types of PNP switches:
https://www.tascaparts.com/oem-parts/vo ... ch-8636317
https://www.tascaparts.com/oem-parts/vo ... ch-8636441
The electric plug is different. The switches still might be compatible, because PNP is actuated mechanically via gear selector and PRND part of travel is the same.
Geartronic +/- has nothing to do with PNP switch: it stays in Drive, + and - are detected via push buttons.
And I was wrong: 3 bolts/nuts :)
dejanaleksov
Year and Model: 2001V70xc
Post by dejanaleksov »
Thanks vtl.you are a real saver.i have pn/8636441 judging by the electrical plug...if it's mechanical I suppose it's gona work? Now just came back from work and in front of my house I lost 3Rd gear and 1St gear, never got speed for 5 th gear... Only 2 ND, 4 th gear and reverse. Im a confused about the plates on the boxes. Mine is 00M-V70-7655 and the donor box says 00E-V71-1931. The first two number is the production date,the letter is weeks of prod. And then is V70???? And four numbers. The donor box is also 00E (probably only weeks apart) but it says V71????...? Who is the V 71? Also what's the number on the upper right corner, maybe part number? So many questions, so little knowledge :-)
vtl
Post by vtl »
I don't know how to decode that.
You need the same gear ratio and AWD differential. Maybe the same type of valve body (same stamped letter), but here I'm not sure.
dejanaleksov
Maybe someone can decode that? As for the gear ratios im not sure maybe they r different differ.the valve body should be the same no letter or a letter, but the adaptation should solve that right?come on guys, I know there is someone who knows this things /numbers /swaps...Jrl Astro please say something... Anyway thanks guys especially vtl.
dejanaleksov
I read the codes p1618 and p0733 gear 3 incorect gear ratio...clear the codes, went for a drive and excelent changing through the gear,and the codes are back after 20 min driving, again lost 3 Rd gear,and heavy slipping.So I disconnect the upper return hose from the radiator to see if atf is flowing.I start the car and it has a good flow,comparing when I did a flush a year ago when the box was OK it has the same flow rate. So it has atf flow the pump is pumping atf at a good rate...I thought its not pumping at all because of the winning sound and maybe a clogged filter? Hmmm out of thoughts and out of gears :-)
vtl
Post by vtl »
Check B4 servo cap.
Someone here or on volvoxc.com took one washer out, with a good result w.r.t. dreaded 2-3 shift.
dejanaleksov
Thanks vtl. I'm still waiting for the b4 servo to arrive. I can't wait to change the b4
MDK
Year and Model: 2004 S60R
Been thanked: 42 times
Post by MDK »
XC70 AWD front half shafts will NOT fit into a FWD transmission.. I know that for sure... MDK
dejanaleksov
I didn't know that. Thanks mdk. Why they will not fit? Different parts altogether? Different partnumber? Different diameter?
